ASR-F-5-2F
ASR-F-5-2F
    YEZHAN(业展)
    电流采样电阻 3920 2mΩ ±1% ±50ppm/℃ 6W
ASR-F-5-2F 数据手册
◆Features ·Power rating up to 15 W ·Excellent long-term stability ·Ideal for mounting on DCB/IMS substrate ·RoHS compliant ·AEC-Q200 qualified ◆Applications ·Current sensor for power hybrid applications ·Frequency converters ·Power modules ·Automatic control power supply ·High current applications for the automotive market ◆Technical Date Resistance m0hm 0.1 to 5 Tolerance % 1、2、5 Power P70℃ W 3~15 Recommended applicable temperature range ℃ -65℃ to +170℃ ◆Ordering Code ASR M 3 1 F Product Material Dimension R Value R Tolerance M:Manganin 3:2512 Unit:mΩ J:± 5% K:Kamar 5:3920 G:± 2% S:CuMn7Sn 7:5930 F:± 1% Type F:FeCrAl … ◆Physical Dimensions Type Size W/mm A/mm C/mm H/mm l w a ASR-S/M/K/F-3 2512 6.3±0.2 1.2±0.2 3.1±0.3 0.5±0.1 7 3.4 1.8 ASR-S/M/K/F-5 3920 10±0.2 2.2±0.2 5.1±0.4 0.5±0.1 11 6.2 2.7 ASR-S/M/K/F-7 5930 15±0.3 4.2±0.3 7.6±0.4 0.5±0.1 16 8.75 5.2 深圳市业展电子有限公司 Tel:0755-29500756 E-mail:business@yezhan.com.cn 1 ◆ Electrical Features Type Resistance/mΩ D1 /mm D2 /mm ASR-S-3 0.2 1.40 1.40 P70℃ /W 6 TCR /ppm/℃ 175 0.3 1.50 1.50 6 175 0.5 0.88 0.88 6 115 1 0.50 0.50 5 100 2 0.65 0.65 5 50 3 0.43 0.43 4 50 4 0.3 0.3 3 50 2 0.7 0.7 5 50 3 0.47 0.47 4 50 4 0.35 0.35 3 50 5 0.28 0.28 3 50 0.2 1.66 1.66 12 200 0.3 1.37 1.37 10 150 0.5 0.83 0.83 9 70 1 0.40 0.40 7 50 1 1.16 1.16 8 50 2 0.56 0.56 6 50 3 0.37 0.37 5 50 4 0.28 0.28 5 50 1 1.28 1.28 8 50 2 0.64 0.64 6 50 3 0.43 0.43 5 50 4 0.32 0.32 5 50 0.1 2.0 2.0 15 200 0.2 1.50 1.50 15 100 0.3 0.98 0.98 10 100 0.5 0.60 0.60 10 75 0.75 0.41 0.41 10 75 1 0.86 0.86 9 50 2 0.40 0.40 7 50 3 0.29 0.29 7 50 1 0.96 0.96 9 50 2 0.48 0.48 7 50 3 0.32 0.32 7 50 ASR-M-3 ASR-K-3 ASR-F-3 ASR-M-5 ASR-K-5 ASR-F-5 ASR-S-7 ASR-M-7 ASR-K-7 ASR-F-7 深圳市业展电子有限公司 Tel:0755-29500756 E-mail:business@yezhan.com.cn 2 ◆ Power derating curve at 70 ℃ P (W) 6 4 2 0 0 20 40 60 80 100 120 140 160 Terminal Temperature ◆ 180 o T[ C] Stability < 1.0% (in covered condition) Performance Date Iterms Additional Requirements Reference JESD22 Temperature 1000 Cycles(-55℃ to +125℃) Cycling Measurement at 24± 2hours after test conclusion High Temperature 1000hrs.@T=125℃.Unpowered. MIL-STD-202 Exposure Measurement at 24± 2hours after test conclusion Method 108 1000hrs 85℃/85%RH。Note: Specified conditions: Biased Humidity 10% of operating power. Measurement at 24± 2hours after test conclusion Operational Life Limits Method ± 0.5% JA-104 MIL-STD-202 Method 103 Condition D Steady State TA=125℃ at rated power. MIL-STD-202 Measurement at 24± 2hours after test conclusion Method 108 ± 0.5% ± 0.5% ± 1% 95% Solderability 245℃± 5℃,5s+0.5s/-0 J-STD-002C Coverage Min Resistance to 260℃± 5℃,10s± 1s MIL-STD-202 Soldering Heat Measurement at 24± 2hours after test conclusion Method 210 Short Time 5× Rated power for 5 s MIL-STD-202 Overload Measurement at 24± 2hours after test conclusion Method 301 深圳市业展电子有限公司 Tel:0755-29500756 E-mail:business@yezhan.com.cn 3 ± 0.5% ± 0.5% Marking R001 1% R001:1mΩ 1%:Tolerance 包装 Packaging Embossed plastic Tape Specifications (Unit:mm) Size A B W E F P0 P1 P2 D0 T Quantity 2512 4.3 7.6 16 1.55 7.5 3.85 7.7 7.7 1.50 1.7 1000 3920 6 11 24 1.55 11.2 6 12 12 1.50 2.0 2500 5930 8.6 16 24 1.55 10.8 6 12 12 1.50 2.4 2000 深圳市业展电子有限公司 Size 2512 3920 5930 φA 330 330 330 φB 99.5 99.5 99.5 φC 13 13 13 W 16.5 24.5 24.5 T 21 29 29 Tel:0755-29500756 E-mail:business@yezhan.com.cn 4
ASR-F-5-2F
1. 物料型号:文档中提到的电阻型号包括ASR-S、ASR-M、ASR-K和ASR-F,它们分别对应不同的尺寸和电阻值。
2. 器件简介:这些毫欧电阻具有高达15W的功率等级、出色的长期稳定性,并且适合安装在DCB/IMS基板上。它们符合RoHS标准并已通过AEC-Q200认证。
3. 引脚分配:文档中没有明确提到引脚分配,但提供了电阻的尺寸和物理参数。
4. 参数特性:电阻的参数包括阻值范围(0.1至5毫欧)、公差(1%、2%、5%)、功率(3至15瓦特)和推荐的工作温度范围(-65°C至+170°C)。
5. 功能详解:这些电阻适用于电流传感器、功率混合应用、频率转换器、功率模块、自动控制电源和汽车市场的高电流应用。
6. 应用信息:文档列出了电阻的应用领域,包括上述提到的几个方面。
7. 封装信息:提供了不同型号电阻的物理尺寸和电气特性,包括直径D1、D2,功率P70°C/W和温度系数TCR。
ASR-F-5-2F 价格&库存
很抱歉,暂时无法提供与“ASR-F-5-2F”相匹配的价格&库存,您可以联系我们找货
