BM20B-ZPDSS-TF(LF)(SN)
    JST
    SMD,P=1.5mm
    线对板针座 2x10P 立贴 间距:1.5mm
BM20B-ZPDSS-TF(LF)(SN) 数据手册
Emboss Tape ZPD CONNECTOR 1.5mm pitch/Disconnectable Crimp style connectors • Secure locking structure • Low insertion force • Suction area for picking up • Improvement of engagement with prying Specifications ––––––––––––––––––– • Current rating: 10 to 30 circuits/ 2 A AC, DC (AWG #24) 32 to 40 circuits/ 1.5 A AC, DC (AWG #24) • Voltage rating: 100 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 30 mΩ max. After environmental tests/ 60 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #24 Insulation O.D./ 0.76 to 1.2 mm In order to correspond to the high-density PC board designing, this ZPD connector is designed as 1.5mm pitch double row type connector with secure locking device. Low insertion force is realized and good mating feeling is also prepared, and these provide the certain mating operation. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards –––––––––––––––––––––– 0 Recognized E60389 1Certified LR20812 PC board layout and Assembly layout Top entry type Side entry type ±0.05 1.5 ±0.05 ±0.1 1 ±0.1 C ±0.1 1 A (Mating side) Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 1 1.7 (9.2) ±0.1 ±0.05 0.7 (10.5) 8.3 Circuit No.N ±0.05 1.7 Circuit No.1 Circuit No.N-1 Circuit No.2 ±0.05 3.5 Circuit No.N-1 Circuit No.1 1.7 Circuit No.2 (9.5) 8.95 2.8 Connector outline 1.7 1.5 Circuit No.N ±0.05 (8.6) ±0.05 ±0.05 0.7 ±0.1 ±0.1 ±0.05 ±0.05 ±0.05 A Connector outline ZPD CONNECTOR Contact Applicable wire AWG# mm2 Model No. SZPD-002T-P0.3 0.08∼0.21 28∼24 Insulation O.D. (mm) Q´ty/ reel 0.76∼1.2 16,000 6.6 2.9 3.15 Material and Finish 1 Copper alloy, tin-plated (reflow treatment) 1.07 RoHS compliance Contact Crimping machine Crimp applicator SZPD-002T-P0.3 AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SZE-002-03 APLMK SZE002-03 Housing B 8.6 Circuit No.1 mark Circuits Model No. 10 ZPDR-10V-S ZPDR-12V-S ZPDR-14V-S ZPDR-16V-S ZPDR-18V-S ZPDR-20V-S ZPDR-22V-S ZPDR-24V-S ZPDR-26V-S ZPDR-28V-S ZPDR-30V-S ZPDR-32V-1-Z ZPDR-34V-1-Z ZPDR-36V-1-Z ZPDR-38V-1-Z ZPDR-40V-1-Z 12 14 7.6 16 18 20 22 1.5 24 A 26 28 30 32 34 B 8.6 36 Circuit No.1 mark 38 7.6 40 Dimensions (mm) A B Q'ty/ bag 6.0 11.2 1,000 7.5 12.7 1,000 9.0 14.2 1,000 10.5 15.7 1,000 12.0 17.2 1,000 13.5 18.7 1,000 15.0 20.2 1,000 16.5 21.7 1,000 18.0 23.2 1,000 19.5 24.7 500 21.0 26.2 500 22.5 27.7 500 24.0 29.2 500 25.5 30.7 500 27.0 32.2 500 28.5 33.7 500 Material PBT, UL94V-0, natural (10 to 30 circuits), ivory (32 to 40 circuits) 1.5 RoHS compliance A As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B 8.6 ZPDR-10V-S10 to 30 circuits Circuit No.1 mark 7.6 32 to 40 circuits S...natural Z...ivory MG...moss green TR...tomato red DPK...dark pink E...blue Z...ivory K...black 1.5 A B 8.6 7.6 Circuit No.1 mark 1.5 A 2 ZPD CONNECTOR Shrouded header Top entry type Side entry type B 6.7 0.3 B 1 7.4 0.6 Circuit No.1 mark (8) 7.85 5.55 (5.7) Circuit No.1 mark 1.5 1.5 A A B 6.7 0.3 B 1 7.4 Circuit No.1 mark 0.6 (8) 7.85 5.55 (5.7) Circuit No.1 mark 1.5 1.5 A A B 7.4 B 1 0.3 1.5 1.5 A A Top entry type Side entry type Circuits Model No. 10 BM10B-ZPDSS-TF BM12B-ZPDSS-TF BM14B-ZPDSS-TF BM16B-ZPDSS-TF BM18B-ZPDSS-TF BM20B-ZPDSS-TF BM22B-ZPDSS-TF BM24B-ZPDSS-TF BM26B-ZPDSS-TF BM28B-ZPDSS-TF BM30B-ZPDZS-TF BM32B-ZPDZS-TF BM34B-ZPDZS-TF BM36B-ZPDZS-TF BM38B-ZPDZS-TF BM40B-ZPDZS-TF 14 16 18 20 22 24 26 28 30 32 34 36 38 40 Dimensions (mm) A B C Q'ty/ reel Circuits Model No. 6.0 11.2 9.2 1,000 10 7.5 12.7 10.7 1,000 12 9.0 14.2 12.2 1,000 14 10.5 15.7 13.7 1,000 16 12.0 17.2 15.2 1,000 18 13.5 18.7 16.7 1,000 20 15.0 20.2 18.2 1,000 22 16.5 21.7 19.7 1,000 24 18.0 23.2 21.2 1,000 26 19.5 24.7 22.7 1,000 28 21.0 26.2 24.2 1,000 30 22.5 27.7 25.7 1,000 32 24.0 29.2 27.2 1,000 34 25.5 30.7 28.7 1,000 36 27.0 32.2 30.2 1,000 38 28.5 33.7 31.7 1,000 40 SM10B-ZPDSS-TF SM12B-ZPDSS-TF SM14B-ZPDSS-TF SM16B-ZPDSS-TF SM18B-ZPDSS-TF SM20B-ZPDSS-TF SM22B-ZPDSS-TF SM24B-ZPDSS-TF SM26B-ZPDSS-TF SM28B-ZPDSS-TF SM30B-ZPDSS-TF SM32B-ZPDZS-TF SM34B-ZPDZS-TF SM36B-ZPDZS-TF SM38B-ZPDZS-TF SM40B-ZPDZS-TF 11.2 700 7.5 12.7 700 9.0 14.2 700 10.5 15.7 700 12.0 17.2 700 13.5 18.7 700 15.0 20.2 700 16.5 21.7 700 18.0 23.2 700 19.5 24.7 700 21.0 26.2 700 22.5 27.7 700 24.0 29.2 700 25.5 30.7 700 27.0 32.2 700 28.5 33.7 700 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural (10 to 30 circuits) LCP, UL94V-0, ivory (32 to 40 circuits) RoHS compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape. BM10B-ZPDSS-TF- SM10B-ZPDSS-TF10 to 30 circuits S...natural Z...ivory MG...moss green TR...tomato red DPK...dark pink E...blue 32 to 40 circuits Z...ivory K...black Q'ty/ reel 6.0 Material and Finish As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3 Dimensions (mm) A B Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural (10 to 30 circuits) LCP, UL94V-0, ivory (32 to 40 circuits) Reinforcing tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape. ex. 0.6 (8) 7.85 (5.7) 5.55 Circuit No.1 mark 12 6.7 Circuit No.1 mark
1. 物料型号:文档列出了不同型号的ZPD连接器,例如SZPD-002T-P0.3,ZPDR-10V-S至ZPDR-40V-1-Z,以及BM和SM系列的带状头。
2. 器件简介:ZPD连接器设计为1.5mm间距的双排连接器,具有安全锁定装置,低插入力和良好的配合感觉。
3. 引脚分配:文档提供了连接器的PCB布局和组装布局图,展示了不同电路编号的引脚位置。
4. 参数特性:包括电流额定值、电压额定值、温度范围、接触电阻、绝缘电阻、耐电压和适用电线规格。
5. 功能详解:文档描述了连接器的安全锁定结构、低插入力和顶出时的配合改进。
6. 应用信息:提供了连接器的适用电线规格和颜色标识信息。
7. 封装信息:列出了不同电路数量的连接器的尺寸和每卷/袋的数量。
BM20B-ZPDSS-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BM20B-ZPDSS-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+15.682231+2.02892
    • 10+14.6533510+1.89581
    • 30+11.1269230+1.43957
    • 50+10.4216350+1.34832
    • 100+9.89060100+1.27962
    • 300+9.53380300+1.23346
    • 500+9.46742500+1.22487
    库存:1503
    • 1+6.655451+0.86106
    • 50+5.1619150+0.66783
    • 100+4.62039100+0.59777
    • 300+4.26229300+0.55144
    • 500+4.18368500+0.54127
    • 1000+4.131271000+0.53449
    库存:980
      • 1+8.664321+1.12096
      • 10+5.2317810+0.67687
      • 50+4.6815350+0.60568
      • 100+4.31469100+0.55822
      • 500+4.23608500+0.54805
      • 1000+4.183681000+0.54127
      • 2000+4.157482000+0.53788
      库存:1
