SHR-13V-S
SHR-13V-S
    JST
    P=1mm
    1X13P 1MM
SHR-13V-S 数据手册
Emboss Tape SH CONNECTOR 1.0mm pitch/Disconnectable Crimp style connectors Specifications ––––––––––––––––––– • Current rating: 1.0 A AC, DC (AWG #28) • Voltage rating: 50 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 40 mΩ max. • Insulation resistance: 100 MΩ min. • Withstanding voltage: 500 VAC/minute • Applicable wire: Conductor size/ AWG #32 to #28 Insulation O.D./ 0.4 to 0.8 mm 15 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. 14 13 12 11 10 9 8 7 6 5 3 4 2 The world's first 1.0mm pitch crimp style connector. • Compact, low profile design • Compatible with the SR insulation displacement connectors • Housing lances Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout and Assembly layout Top entry type Side entry type 0.2 ±0.1 2.9 0.7 ±0.1 1.2 ±0.1 1 ±0.05 1.2 ±0.1 Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. The dimensions above should serve as a guideline. Contact JST for details. 2.95 0.2 ±0.1 0.7 ±0.1 1.8 ±0.1 1±0.05 5.55 ±0.1 6.3 4.2 ±0.1 6.25 4 ±0.1 0.6 ±0.05 2.65±0.1 0.6 ±0.05 1.8 ±0.1 Header outline Header outline Contact Model No. mm2 SSH-003T-P0.2-H Applicable wire Insulation O.D. (mm) AWG# 0.032∼0.08 32∼28 0.4∼0.8 Q'ty/ reel 23,000 Material and Finish 3.9 2 1.6 0.8 RoHS compliance Note: Contact JST for gold-plated products. 0.8 1.55 1.35 0.5 Phosphor bronze, tin-plated (reflow treatment) 0.45 Contact Crimping machine Crimp applicator SSH-003T-P0.2-H AP-K2N Applicator Dies Crimp applicator with dies MKS-L-10-3 MK/SSH/L-003-02 APLMK SSH/L003-02 *MKS-SC SC/SSH/L-003-02 APLSC SSH/L003-02 Note: *Strip-crimp applicator Contact JST for applicable wires in case that it is not usable due to wire size. 1 SH CONNECTOR Housing With protrusions B 2 A 1 Circuit No.1 3 2.8 4 5 N 3 2 6 5 7 8 9 10 11 2.1 12 Without protrusions 13 14 B 15 A 1 Circuit No.1 Model No. Circuits 20 2.8 A With protrusions Without protrusions SHR-02V-S-B SHR-02V-S SHR-03V-S-B SHR-03V-S SHR-04V-S-B SHR-04V-S SHR-05V-S-B SHR-05V-S SHR-06V-S-B SHR-06V-S SHR-07V-S-B SHR-07V-S SHR-08V-S-B SHR-08V-S SHR-09V-S-B SHR-09V-S SHR-10V-S-B SHR-10V-S SHR-11V-S-B SHR-11V-S SHR-12V-S-B SHR-12V-S SHR-13V-S-B SHR-13V-S SHR-14V-S-B SHR-14V-S SHR-15V-S-B SHR-15V-S ― SHR-20V-S-B Dimensions (mm) Q'ty/ B box With protrusions Without protrusions 1.0 5.0 3.0 2,000 2.0 6.0 4.0 2,000 3.0 7.0 5.0 2,000 4.0 8.0 6.0 2,000 5.0 9.0 7.0 2,000 6.0 10.0 8.0 2,000 7.0 11.0 9.0 2,000 8.0 12.0 10.0 2,000 9.0 13.0 11.0 2,000 10.0 14.0 12.0 2,000 11.0 15.0 13.0 2,000 12.0 16.0 14.0 2,000 13.0 17.0 15.0 2,000 14.0 18.0 16.0 2,000 19.0 23.0 21.0 1,000 Material N PBT, UL94V-0, natural (white) 3 2 5 RoHS compliance 2.1 Shrouded header The shrouded headers are interchangeable with those of the SR insulation displacement connectors. Top entry type Circuits 4.25 1.5 A 2.9 0.7 B Side entry type Circuit No.1 Dimensions (mm) A B Q’ty/reel Top entry type Side entry type 2 BM02B-SRSS-TB SM02B-SRSS-TB 1.0 4.0 1,500 3,000 3 BM03B-SRSS-TB SM03B-SRSS-TB 2.0 5.0 1,500 3,000 4 BM04B-SRSS-TB SM04B-SRSS-TB 3.0 6.0 1,500 3,000 5 BM05B-SRSS-TB SM05B-SRSS-TB 4.0 7.0 1,500 3,000 6 BM06B-SRSS-TB SM06B-SRSS-TB 5.0 8.0 1,500 3,000 7 BM07B-SRSS-TB SM07B-SRSS-TB 6.0 9.0 1,500 3,000 8 BM08B-SRSS-TB SM08B-SRSS-TB 7.0 10.0 1,500 3,000 9 BM09B-SRSS-TB SM09B-SRSS-TB 8.0 11.0 1,500 3,000 10 BM10B-SRSS-TB SM10B-SRSS-TB 9.0 12.0 1,500 3,000 11 BM11B-SRSS-TB SM11B-SRSS-TB 10.0 13.0 1,500 3,000 12 BM12B-SRSS-TB SM12B-SRSS-TB 11.0 14.0 1,500 3,000 13 BM13B-SRSS-TB SM13B-SRSS-TB 12.0 15.0 1,500 3,000 14 BM14B-SRSS-TB SM14B-SRSS-TB 13.0 16.0 1,500 3,000 15 BM15B-SRSS-TB 14.0 17.0 1,500 3,000 20 ― SM15B-SRSS-TB SM20B-SRSS-TB 19.0 22.0 ― 3,000 Circuit No.1 1 Model No. Top entry type Side entry type 2.9 Material and Finish 1 Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Housing: PA, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 1.5 A B 4.25 0.7 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the headers with gold-plated pins. 3. Contact JST for the top entry type headers with suction cap. 2
SHR-13V-S 价格&库存
很抱歉,暂时无法提供与“SHR-13V-S”相匹配的价格&库存,您可以联系我们找货
SHR-13V-S
  • 1+1.965681+0.25441
  • 10+1.6633510+0.21528
  • 25+1.5584425+0.20170
  • 50+1.4834550+0.19199
  • 100+1.41251100+0.18281
  • 250+1.32363250+0.17131
  • 500+1.26028500+0.16311
  • 2000+1.142612000+0.14788
  • 4000+1.088034000+0.14082
库存:6015
SHR-13V-S
    库存:2000
    SHR-13V-S
      库存:42880
      SHR-13V-S
        • 2000+0.52030
        库存:4000
        SHR-13V-S
          • 500+0.49390
          库存:7256
          SHR-13V-S
            • 1+1.763691+0.22826
            • 10+1.3795210+0.17854
            • 50+1.0215450+0.13221
            • 100+0.94296100+0.12204
            • 500+0.89058500+0.11526
            • 1000+0.864381000+0.11187
            • 2000+0.855652000+0.11074
            库存:1287
