規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
单指向驻极体咪头(ECM)
TYPE
: GMI6027U-32-66DB
DESCRIPTION : φ6.0 x H2.7mm 背极式
客戶料號
CUSTOMER NO. :
規 格 書 號
-32~-66dB
0.68K
1.5V
S/N: ≥58 dBA
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
李林
地址:廣東省東莞市長安鎮廈邊元灶頭工業區 16-6 號
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/5
A. SCOPE
This specification applies electret condenser microphone, GMI6027U-32-66DB
B. SPECIFICATION
■Test condition: RL=0.68KΩ
No.
Item
1
Directivity
2
Sensitivity
3
VS=1.5V
Symbol
Unit
TEMP=25℃±2℃
Specification
Related humidity=65±5%
Condition
Unidirectional
f=1KHz,0dB=1V/ Pa
S
dB
-32~-66±3
Standard operating voltage
Vs
V
1.5
4
Output impedance
Zout
KΩ
≤0.68
5
Frequency
Hz
100-10,000
6
Max operating voltage
V.
10
7
Sensitivity reduction
△S-Vs
dB
-3
8
Max. current consumption
IDSS
mA
≤0.5
9
Signal to noise ration
S/N
dBA
≥58
10
Max input sound level
SPL
dB
110
11
Operation temp.
-20 ~+60
12
Storage temp.
-30 ~+70
13
Dimension
mm
φ6.0xH2.7
See appearance drawing
14
Terminal
Terminal
15
Approvals
RoHs FCC
f=1KHz, 1Pa
f=1KHz, 1Pa
vs=3.0VDC to 1.5VDC
We use “Pascal(Pa)”indication of sensitivity as per the recommendation of I.E.C.(International Electro technical
Commission)
TheSensitivity of “Pa” will increase 20dB comparing with “ubar” indication
Example: -60dB(0dB=1V/ubar) =-40dB(1V/Pa)
2/5
C.TYPICAL FREQUENCY RESPONSE CURVE
Relative Response(dB)
Frequency Response
Microphone Response Tolerance Window
Frequency(Hz) Lower Limit(dB) Upper Limit(dB)
100
-5
5
0°
180°
D. APPEARANCE DRAWING
200
-5
5
800
-5
5
1000
-5
5
2000
-5
5
5000
-5
5
10000
-8
8
2.7±0.1
Unit: mm
Φ6.0±0.1
E. MEASUREMENT CIRCUIT
FET impedance
Converter
C
Term.1
Output
RL
ECM
Unit
+Vs
Term.2
Shielb case
Ground
RL=2.2KΩ(External resistor)
3/5
F.Explode Drawing
背极膜
外壳
金环
防水网
塑环
阻尼棉
背极板
电容
垫片
G. 可靠性试验
Reliability Test
经过以下所有试验在 20℃的条件下放置 3 小时后,麦克风的灵敏度与试验前比较变化在 3dB 以
内
After any following tests, the sensitivity of the microphone to be within ±3dB of initial sensitivity
after 3hours of conditioning at 20℃
5-1 振动试验
周波数 1/Frequency1:10Hz~55Hz
Vibration
振幅/Amplitude:1.52mm
变化/Change of Frequency:1 octave/min
3 方向,各 2 小时/hours in each of 3 axes
5-2 高温试验
+60±5℃ for 96 hours
Dry Heat
5-3 低温试验
-20±5℃ for 96 hours
Dry Cold
5-4 高温高湿试验
90%~95%RH,+60±5℃ for 96 hours
Damp Heat
5-5 温度循环试验
-20℃
25℃
60℃
Temperature cycles
(2h) (1h) (2h) (1h) (2h)×10 cycles
5-6 跌落试验
Height:1m
Packing drop test
顺序:三个面各跌 10 次
Procedure:10 times from each of 3 axises
5-7 温度冲击试验
-20℃
60℃
Temperature impact test
30min 30s
30min ×10 cycles
5-8 静电冲击试验
4000V(contact), 8000V(air) ×10 axises
Electrostatic shock test
备注 Note
6-1 工作温度范围
-20℃~60℃
Operation Temperature
6-2 储存温度范围
-30℃~70℃
Storage Temperature
4/5
H. 焊接条件 Soldering Condition
7-1 焊接使用 90W 的烙铁。
The soldering copper of a type of 90W shall be applied
焊接条件
Soldering Condition.
7-2 电烙铁表面温度 320±10℃
The temperature of the working surface of the soldering copper shall be 320±10℃
7-3 焊接时把麦克风嵌入散热能力强的金属块内。
ECM shall be soldered fixed on the metal block(heat sink)which has the higher radiation effects said
heat sink Shall contact with of ECM.
7-4 焊接时间控制在 2~3 秒内。
time for each terminal shall be 2~3 sec.
7-5 焊接后不能出现针孔。
The pinhole after soldering shall be avoided.
7-6 静电容易破坏麦克风必须采取措施避免(电烙铁接地,戴静电环等。)
ECM may easily destroyed by the static electricity and the countermeasure for eliminating the static
electricity (the ground for soldering copper, for worktable and for human body) shall be executed.
7-7 散热板形状 Shape of heat sink
7-8 固定部孔形状 Shape of hole at fixed part
5/5
很抱歉,暂时无法提供与“GMI6027U-56DB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.14372
- 10+0.61776
- 30+0.27324
- 100+0.23760
