SS14F
SS14F
    YENJI(台湾元基)
    SMAF
    肖特基二极管 Single VR=40V IF=1A SMAF
SS14F 数据手册
SS12~SS120 1.0Amp Surface Mounted Schottky Barrier Rectifiers Features DO-214AC/SMA The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications 0.110(2.80) 0.094(2.40) 0.067 (1.70) 0.051 (1.30) Built-in strain relief,ideal for automated placement Low reverse leakage High forward surge current capability 0.177(4.50) 0.153(3.90) High temperature soldering guaranteed 0.012(0.305) 0.006(0.152) 250 C/10 seconds at terminals 0.098(2.50) 0.078(2.00) Mechanical Data Case : Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.208(5.30) 0.188(4.80) Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0023 ounce, 0.07 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load, for capacitive load current derate by 20%. Parameter SYMBOLS SS12 SS14 SS145 SS16 SS18 SS110 SS115 SS120 UNITS Maximum repetitive peak reverse voltage VRRM 20 40 45 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 31.5 42 56 70 105 140 V Maximum DC blocking voltage VDC 20 40 45 60 80 100 150 200 V Maximum average forward rectified current at TL =100 C I(AV) 1.0 A Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 30.0 A Maximum instantaneous forward voltage at 1.0A VF Maximum DC reverse current T A =25 C at rated DC blocking voltage TA=125 C Typical thermal resistance Operating junction temperature range Storage temperature range 0.55 0.70 0.85 0.5 50 IR 0.95 0.05 10 80.0 RqJA -55 to +150 TSTG 1/3 mA C/W -55 to +150 -55 to +125 TJ V C C SS12~SS120 1.0Amp Surface Mounted Schottky Barrier Rectifiers Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 35 Peak Forward Surage Current Amperes 1.0 0.9 0.8 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 0.7 0.6 0.5 0.4 SS12-SS16 SS18-SS1200 0.3 0.2 0 20 40 60 80 100 120 140 30 25 20 15 f=60Hz 10 5 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 TJ=25 C INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES SS12-SS16 SS18-SS1200 10.0 1 0.1 SS12-SS145 SS16 SS18-SS1100 SS115-SS1200 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 10 TJ=100 C 1 0.1 0.01 0.001 0 TJ=25 C 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% Suggested Pad Layout Symbol Unit (mm) Unit (inch) A 1.68 1.52 0.066 B C 3.90 0.154 D 2.41 0.095 E 5.45 0.215 2/3 0.060 SS12~SS120 1.0Amp Surface Mounted Schottky Barrier Rectifiers Suggested Soldering Temperature Profile Note R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder. Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s. D evices can b e cleaned using standa rd industry m ethods and solvents. If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e p e rfo rm a n c e re q u ire m e n ts . Package Information Carrier Dimension(mm) A0 B0 K0 D0 E F 2.80 5.30 2.36 1.55 1.75 5.50 P0 P1 P2 T W Tolerance 4.0 4.0 2.0 0.25 12 0.1 Package Specifications Reel DIA. (mm) Q'TY/Reel (Kpcs) Box Size (mm) QTY/Box (Kpcs) Carton Size (mm) Q'TY/Carton (Kpcs) 11' 278 5 285 10 355*310*310 80 13' 330 7.5 340 15 360*360*360 120 Package Reel Size SMA 3/3
SS14F 价格&库存
很抱歉,暂时无法提供与“SS14F”相匹配的价格&库存,您可以联系我们找货
SS14F
  • 20+0.08058
  • 100+0.07293
  • 500+0.06783
  • 1000+0.06273
  • 5000+0.05661
  • 10000+0.05406
库存:5900
