SS12~SS120
1.0Amp Surface Mounted Schottky Barrier Rectifiers
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
0.110(2.80)
0.094(2.40)
0.067 (1.70)
0.051 (1.30)
Built-in strain relief,ideal for automated placement
Low reverse leakage
High forward surge current capability
0.177(4.50)
0.153(3.90)
High temperature soldering guaranteed
0.012(0.305)
0.006(0.152)
250 C/10 seconds at terminals
0.098(2.50)
0.078(2.00)
Mechanical Data
Case : Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.208(5.30)
0.188(4.80)
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0023 ounce, 0.07 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,
for capacitive load current derate by 20%.
Parameter
SYMBOLS
SS12 SS14 SS145 SS16 SS18 SS110
SS115 SS120 UNITS
Maximum repetitive peak reverse voltage
VRRM
45
60
80
100
150
200
V
Maximum RMS voltage
VRMS
14
28
31.5
42
56
70
105
140
V
Maximum DC blocking voltage
VDC
45
60
80
100
150
200
V
Maximum average forward rectified current
at TL =100 C
I(AV)
1.0
A
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
IFSM
30.0
A
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current T A =25 C
at rated DC blocking voltage TA=125 C
Typical thermal resistance
Operating junction temperature range
Storage temperature range
0.55
0.70
0.85
0.5
50
IR
0.95
0.05
10
80.0
RqJA
-55 to +150
TSTG
1/3
mA
C/W
-55 to +150
-55 to +125
TJ
V
C
C
SS12~SS120
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT PERLEG
35
Peak Forward Surage Current
Amperes
1.0
0.9
0.8
Amperes
Average Forward Rectified Current
FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT
0.7
0.6
0.5
0.4
SS12-SS16
SS18-SS1200
0.3
0.2
60
80
100
120
140
30
25
f=60Hz
10
5
1Cycle
1
10
100
Lead Temperature
Number of cycles
FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS
FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS
50
100
TJ=25 C
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
SS12-SS16
SS18-SS1200
10.0
1
0.1
SS12-SS145
SS16
SS18-SS1100
SS115-SS1200
0.01
0.4
0.6
0.8
1.0
1.2
1.4
1.6
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
10
TJ=100 C
1
0.1
0.01
0.001
TJ=25 C
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.68
1.52
0.066
B
C
3.90
0.154
D
2.41
0.095
E
5.45
0.215
2/3
0.060
SS12~SS120
Suggested Soldering Temperature Profile
Note
R ecom m ended reflow m ethods: IR , vap or phase ov en, hot air oven, w ave solder.
Th e dev ice can b e exp osed to a m axim um tem p erature of 265 °C for 10 second s.
D evices can b e cleaned using standa rd industry m ethods and solvents.
If reflow tem peratures exceed the re c o m m e n d e d p ro file , d e v ic e s m a y n o t m e e t th e
p e rfo rm a n c e re q u ire m e n ts .
Package Information
Carrier Dimension(mm)
A0
B0
K0
D0
E
F
2.80
5.30
2.36
1.55
1.75
5.50
P0
P1
P2
T
W
Tolerance
4.0
4.0
2.0
0.25
12
0.1
Package Specifications
Reel DIA.
(mm)
Q'TY/Reel
(Kpcs)
Box Size
(mm)
QTY/Box
(Kpcs)
Carton Size
(mm)
Q'TY/Carton
(Kpcs)
11'
278
5
285
10
355*310*310
80
13'
330
7.5
340
15
360*360*360
120
Package Reel Size
SMA
3/3
很抱歉,暂时无法提供与“SS110”相匹配的价格&库存,您可以联系我们找货
