SD12C
SD12C
    YENJI(台湾元基)
    SOD-323
    ESD抑制器/TVS二极管 VRWM=12V VC=25V SOD323
SD12C 数据手册
SD03C THRU SD24C TVS Diodes Features z z z z z z z z z z Small SOD-323 Package Unidirectional Configurations Peak Power Dissipation 350W @8 x 20 us Pulse Low Leakage Fast Response Time < 5 ns Protects One Power or I/O Port ESD Protection to IEC 61000-4-2 Level 4,15KV(Air), 8KV(Contanct) ESD Protection to IEC 61000-4-2 Level 4, 30A 16KV Human Body Model ESD Requirements RoHS Compliant in Lead-Free Versions Applications z z z z z z Cell Phone Handsets and Accessories Microprocessor Based Equiment Personal Digital Assistant (PDA) Notebooks, Destops, and Servers Portable Instrumentation Pagers Periherals Absolute Maximum Ratings Parameter Symbol Value Units PPK 350 W Air ±15 KV CONTACT ±8.0 KV 30 A VPP 16 KV TSTG -55 to 150 °C TJ -55 to 150 °C Peak Power Dissipation (Note 1.) @TL = 25°C IEC 61000-4-2 (ESD) IEC 61000-4-4 (EFT) ESD Voltage Per Human Body Model Storage Temperature Range Operating Junction Temperature Range 1. 8 X 20 us, non–repetitive 1/3 SD03C THRU SD24C TVS Diodes Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM Working Peak Reverse Voltage IR Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified. VRWM (V) IR(uA) VBR (V)@ IT VC (V) VC (V) @ V RWM (Note 1) IPP C@OV 1MHz @ IPP=5 A* @ Max IPP* (A)* (pF) Device Max Max Min Max mA Typ Max Max Typ SD03C 3.3 10 4.0 6.0 1.0 6.5 10.5 22 320 SD05C 5.0 10 6.2 7.3 1.0 9.8 14.5 20 200 SD12C 12 1.0 13.3 15.75 1.0 19 25 15 100 SD15C 15 1.0 16.7 19.05 1.0 23 28 12 100 SD24C 24 1.0 26.7 30.15 1.0 43 49 10 50 IT *Surge current waveform per Figure 1. 1. V BR is measured with a pluse test current IT at an ambient temperature of 25℃. Fig1. Pulse Waveform Fig2. Power Derating 2/3 SD03C THRU SD24C TVS Diodes Package Dimensions SOD-323 Dim Millimeters Inches MIN NOM MAX MIN NOM MAX A 0.80 0.90 1.00 0.031 0.035 0.040 A1 0.00 0.05 0.10 0.000 0.002 0.004 A3 0.15 REF 0.006 REF b 0.25 0.32 0.4 0.010 0.012 0.016 C 0.080 0.12 0.177 0.003 0.005 0.007 D 1.60 1.70 1.80 0.063 0.066 0.071 E 1.15 1.25 1.40 0.045 0.049 0.055 L 0.08 HE 2.30 0.098 0.106 0.003 2.50 2.70 3/3 0.090
SD12C 价格&库存
很抱歉,暂时无法提供与“SD12C”相匹配的价格&库存,您可以联系我们找货
