SD03C THRU SD24C
TVS Diodes
Features
z
z
z
z
z
z
z
z
z
z
Small SOD-323 Package
Unidirectional Configurations
Peak Power Dissipation 350W @8 x 20 us Pulse
Low Leakage
Fast Response Time < 5 ns
Protects One Power or I/O Port
ESD Protection to IEC 61000-4-2 Level 4,15KV(Air), 8KV(Contanct)
ESD Protection to IEC 61000-4-2 Level 4, 30A
16KV Human Body Model ESD Requirements
RoHS Compliant in Lead-Free Versions
Applications
z
z
z
z
z
z
Cell Phone Handsets and Accessories
Microprocessor Based Equiment
Personal Digital Assistant (PDA)
Notebooks, Destops, and Servers
Portable Instrumentation
Pagers Periherals
Absolute Maximum Ratings
Parameter
Symbol
Value
Units
PPK
350
W
Air
±15
KV
CONTACT
±8.0
KV
30
A
VPP
16
KV
TSTG
-55 to 150
°C
TJ
-55 to 150
°C
Peak Power Dissipation (Note 1.) @TL = 25°C
IEC 61000-4-2 (ESD)
IEC 61000-4-4 (EFT)
ESD Voltage
Per Human Body Model
Storage Temperature Range
Operating Junction Temperature Range
1. 8 X 20 us, non–repetitive
1/3
SD03C THRU SD24C
TVS Diodes
Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwise specified.
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
Working Peak Reverse Voltage
IR
Maximum Reverse Leakage Current @ VRWM
IT
Test Current
VBR
Breakdown Voltage @ IT
Electrical Characteristics Ratings at 25°C ambient temperature unless otherwise specified.
VRWM
(V)
IR(uA)
VBR (V)@ IT
VC (V)
VC (V)
@ V RWM
(Note 1)
IPP
C@OV 1MHz
@ IPP=5 A*
@ Max IPP*
(A)*
(pF)
Device
Max
Max
Min
Max
mA
Typ
Max
Max
Typ
SD03C
3.3
10
4.0
6.0
1.0
6.5
10.5
22
320
SD05C
5.0
10
6.2
7.3
1.0
9.8
14.5
SD12C
12
1.0
13.3
15.75
1.0
19
25
15
100
SD15C
15
1.0
16.7
19.05
1.0
23
28
12
100
SD24C
24
1.0
26.7
30.15
1.0
43
49
10
50
IT
*Surge current waveform per Figure 1.
1.
V BR is measured with a pluse test current IT at an ambient temperature of 25℃.
Fig1. Pulse Waveform
Fig2. Power Derating
2/3
SD03C THRU SD24C
TVS Diodes
Package Dimensions
SOD-323
Dim
Millimeters
Inches
MIN
NOM
MAX
MIN
NOM
MAX
A
0.80
0.90
1.00
0.031
0.035
0.040
A1
0.00
0.05
0.10
0.000
0.002
0.004
A3
0.15 REF
0.006 REF
b
0.25
0.32
0.4
0.010
0.012
0.016
C
0.080
0.12
0.177
0.003
0.005
0.007
D
1.60
1.70
1.80
0.063
0.066
0.071
E
1.15
1.25
1.40
0.045
0.049
0.055
L
0.08
HE
2.30
0.098
0.106
0.003
2.50
2.70
3/3
0.090
很抱歉,暂时无法提供与“SD24C”相匹配的价格&库存,您可以联系我们找货
