PJM2321PSA
P-Channel Power MOSFET
SOT-23
Features
VDS= -20V ID= -2.9A
RDS(ON)= 57mΩ(max) @-4.5V
1. Gate
2.Source
3.Drain
Marking: S21
Schematic Diagram
Application
Load switch and in PWM applicatopns
Power management
Drain
3
1
Gate
2 Source
Absolute Maximum Ratings (Ta=25℃unless otherwise specified)
Symbol
Rating
Units
Drain-to-Source Voltage
VDSS
-20
V
Gate-to-Source Voltage
VGS
±12
V
Continuous Drain Current
ID
-2.9
A
Pulsed Drain Current
IDM
-12
A
Continuous Source-Drain Diode Current
IS
-0.59
A
Power Dissipation
PD
0.35
W
Operating Junction Temperature
TJ
150
TSTG
– 55 to150
Symbol
Typ
Unit
RθJA
357
℃/W
Parameter
Note 1
Operating Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance, Junction to Ambient
www.pingjingsemi.com
Revision:1.0 Jun-2018
Note2
1/5
PJM2321PSA
Electrical Characteristics (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test Condition
Min
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID=-250µA
-20
Drain to Source Leakage Current
IDSS
VDS =-16V,VGS = 0V
Gate-body leakage current
IGSS
Gate threshold voltageNote3
VGS(th)
Type
Max
Units
Static Characteristics
Drain-source on-resistance Note3
Forward tranconductance Note3
RDS(on)
gFS
V
-1
µA
±100
nA
-0.9
V
VGS =-4.5V, ID =-3.3A
57
mΩ
VGS =-2.5V, ID =-2.8A
76
mΩ
VGS =-1.8V, ID =-2.3A
100
mΩ
VGS =±12V, VDS =0V
VDS =VGS, ID =-250µA
VDS =-5V, ID =-3.3A
-0.4
3
S
Dynamic characteristics
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
715
VDS =-6V,VGS =0V,f=1MHz
170
pF
120
Switching Characteristics
Turn-on delay time
Turn-on rise time
Turn-off delay time
25
td(on)
tr
td(off)
ID=-1A, VDD=-6V,
55
VGS=-4.5V,RGEN =1Ω,
90
RL =6Ω,
Turn-off fall time
tf
60
Total gate charge
Qg
13
Gate-source charge
Qgs
Gate-drain charge
Qgd
VDD =-6V,VGS =-4.5V,ID =-4.3A
1.2
ns
nC
1.6
Source-Drain Diode characteristics
Diode Forward voltage
VDS
VGS =0V, IS=-1.6A
1.2
V
Notes:1. Repetitive rating: Pluse width limited by junction temperature.
2. Surface mounted on FR4 board,t ≦ 10 sec.
3. Pulse test: pulse width ≦ 300us, duty cycle≦ 0.5%.
2/5
PJM2321PSA
Typical Characteristic Curves
Output Characteristics
-16
Ta=25℃
Pulsed
Transfer Characteristics
-10
VGS=-4.5V,-4.0V,-3.5V,-3.0V,-2.5V
Ta=25℃
Pulsed
VGS=-2.0V
(A)
ID
DRAIN CURRENT
DRAIN CURRENT
ID
(A)
-8
-12
-8
VGS=-1.5V
-6
-4
-4
-2
-0
VGS=-1.0V
-0
-1
-2
-3
DRAIN TO SOURCE VOLTAGE
RDS(ON) ——
300
VDS
-0
-0.0
-4
(V)
ID
-1.5
RDS(ON) ——
500
-2.0
-2.5
VGS (V)
VGS
Ta=25℃
Ta=25℃
Pulsed
Pulsed
400
(mΩ)
(mΩ)
RDS(ON)
200
150
VGS=-1.8V
100
VGS=-2.5V
50
ON-RESISTANCE
RDS(ON)
-1.0
GATE TO SOURCE VOLTAGE
250
ON-RESISTANCE
-0.5
300
200
ID=-3.3A
100
VGS=-4.5V
-2
-4
-6
DRAIN CURRENT
-8
ID
-10
-12
(A)
-2
-4
-6
VGS
-8
(V)
IS —— VSD
-20
Ta=25℃
Pulsed
SOURCE CURRENT
IS (A)
-10
-3
-1
-0.3
-0.1
-0.2
-0.4
-0.6
-0.8
-1.0
SOURCE TO DRAIN VOLTAGE
-1.2
-1.4
VSD (V)
3/5
PJM2321PSA
Package Outline
SOT-23
0.8
Max.
1.025
1.150
A1
0.000
0.050
0.100
b
c
D
0.300
0.080
2.800
0.400
0.115
2.900
0.500
0.150
3.000
E
1.200
1.300
1.400
HE
2.250
2.400
2.550
e
1.800
1.900
2.000
0.550REF
L1
L
0.300
0o
θ
0.500
8o
2.2
Typ.
0.900
0.8
1.0
Min.
A
1.0
Dimensions in millimeter
Symbol
1.9
SOT-23 (TO-236)
Recommended soldering pad
Ordering Information
Device
Package
Shipping
PJM2321PSA
SOT-23
3000PCS/Reel&Tape
4/5
PJM2321PSA
Package Specifications
The method of packaging
Cover Tape
SOT-23 (TO-236)
3,000 pcs per reel
1
3
2
Carrier Tape
30,000 pcs per box
10 reels per box
220
195
21
43
5
120,000 pcs per carton
4 boxes per carton
210
Embossed tape and reel data
D
A
T2
T1
4.0
4.0
B
8.0
C
E
1Pin
G
N
Tape (8mm)
F
Reel (7'')
Symbol
A
B
C
E
F
D
T1
T2
N
G
Value (unit: mm)
Ø 177.8±1
2.7±0.2
Ø 13.5±0.2
Ø 54.5±0.2
12.3±0.3
9.6+2/-0.3
1.0±0.2
1.2±0.2
3.15±0.1
1.25±0.1
5/5
很抱歉,暂时无法提供与“PJM2321PSA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.45393
- 100+0.38340
- 300+0.34820
