PJ73AL36SC
PJ73AL36SC
    PJ(平晶)
    SOT-23
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:20V 输出电压:3.6V
PJ73AL36SC 数据手册
PJ73ALXXSC Series Low Dropout Regulators Description SOT-23-3 The PJ73ALXXSC series is a set of three-terminal low power high voltage regulators implemented in 2 3 CMOS technology. They allow input voltages as high as 20V. They are available with several fixed 1 output voltages ranging from 2.1V to 9.0V. Because 1.GND 2.VOUT 3.VIN of the low power dissipation, PJ73ALXXSC series are widely used in a variety of equipment such Block Diagram as audio device, video device, communication device and so on. VIN Features  Low power consumption  Low voltage drop  Low temperature coefficient  High input voltage (up to 20V)  Quiescent current : 1.5μA  Output voltage tolerance: ±2%  HAF(halogen and antimony free) is acquired Selection Tablet Designator XX www.pingjingsemi.com Revision:1.1 Oct-2019 VOUT Vref GND PJ73ALXXSC Symbol Description 21 2.1V(output) 23 2.3V 25 2.5V 28 2.8V 30 3.0V 33 3.3V 36 3.6V 40 4.0V 44 4.4V 50 5.0V 90 9.0V 1 / 11 PJ73ALXXSC Series Low Dropout Regulators Absolute Maximum Ratings Note1 Ratings at 25℃ ambient temperature unless otherwise specified. Parameter Limit Unit Supply voltage -0.3 ~ +22 V Storage temperature range -50 ~ +125 ℃ -40 ~ 85 ℃ Operating temperature range Note: 1.Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those conditions is not implied. Exposure to absolutemaximum-rated conditions for extended periods may affect device reliability. Parameter Symbol Value Unit RθJA 286 ℃/W PD 350 mW Junction-to-Ambient Thermal Resistance Power Consumption Electrical Characteristics PJ73AL21SC(TA=25℃) Parameter Symbol Test conditions Min. Typ. Max Unit 2.058 2.10 2.142 V 300 -- -- mA VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA Output current IOUT VIN=VOUT+2.0V Load regulation ΔVOUT Voltage drop Note2 VDIF IOUT=10mA -- 45 55 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V www.pingjingsemi.com Revision:1.1 Oct-2019 VIN=VOUT+2.0V, IOUT=10mA, 2 / 11 PJ73ALXXSC Series Low Dropout Regulators PJ73AL23SC(TA=25℃) Parameter Symbol Test conditions Min. Typ. Max Unit 2.254 2.30 2.346 V 300 -- -- mA VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA Output current IOUT VIN=VOUT+2.0V Load regulation ΔVOUT Voltage drop Note2 VDIF IOUT=10mA -- 40 55 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Min. Typ. Max Unit Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V VIN=VOUT+2.0V, IOUT=10mA, PJ73AL25SC(TA=25℃) Parameter Symbol Test conditions Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA 2.45 2.50 2.55 V Output current IOUT VIN=VOUT+2.0V 300 -- -- mA Load regulation ΔVOUT VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Voltage drop Note2 VDIF IOUT=10mA -- 35 55 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V www.pingjingsemi.com Revision:1.1 Oct-2019 VIN=VOUT+2.0V, IOUT=10mA, 3 / 11 PJ73ALXXSC Series Low Dropout Regulators PJ73AL28SC(TA=25℃) Parameter Symbol Test conditions Min. Typ. Max Unit 2.744 2.80 2.856 V 300 -- -- mA VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA Output current IOUT VIN=VOUT+2.0V Load regulation ΔVOUT Voltage drop Note2 VDIF IOUT=10mA -- 30 55 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Min. Typ. Max Unit Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V VIN=VOUT+2.0V, IOUT=10mA, PJ73AL30SC(TA=25℃) Parameter Symbol Test conditions Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA 2.94 3.0 3.06 V Output current IOUT VIN=VOUT+2.0V 300 -- -- mA Load regulation ΔVOUT VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Voltage drop Note2 VDIF IOUT=100mA -- 210 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V www.pingjingsemi.com Revision:1.1 Oct-2019 VIN=VOUT+2.0V, IOUT=10mA, 4 / 11 PJ73ALXXSC Series Low Dropout Regulators PJ73AL33SC(TA=25℃) Parameter Symbol Test conditions Min. Typ. Max Unit Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA 3.234 3.30 3.366 V Output current IOUT VIN=VOUT+2.0V 300 -- -- mA Load regulation ΔVOUT VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Voltage drop Note2 VDIF IOUT=100mA -- 195 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Min. Typ. Max Unit 3.528 3.60 3.672 V 300 -- -- mA VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V VIN=VOUT+2.0V, IOUT=10mA, PJ73AL36SC(TA=25℃) Parameter Symbol Test conditions Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA Output current IOUT VIN=VOUT+2.0V Load regulation ΔVOUT Voltage drop Note2 VDIF IOUT=100mA -- 180 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V www.pingjingsemi.com Revision:1.1 Oct-2019 VIN=VOUT+2.0V, IOUT=10mA, 5 / 11 PJ73ALXXSC Series Low Dropout Regulators PJ73AL40SC(TA=25℃) Parameter Symbol Test conditions Min. Typ. Max Unit Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA 3.92 4.0 4.08 V Output current IOUT VIN=VOUT+2.0V 300 -- -- mA Load regulation ΔVOUT VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Voltage drop Note2 VDIF IOUT=100mA -- 170 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Min. Typ. Max Unit 4.312 4.4 4.488 V 300 -- -- mA VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V VIN=VOUT+2.0V, IOUT=10mA, PJ73AL44SC(TA=25℃) Parameter Symbol Test conditions Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA Output current IOUT VIN=VOUT+2.0V Load regulation ΔVOUT Voltage drop Note2 VDIF IOUT=100mA -- 160 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V www.pingjingsemi.com Revision:1.1 Oct-2019 VIN=VOUT+2.0V, IOUT=10mA, 6 / 11 PJ73ALXXSC Series Low Dropout Regulators PJ73AL50SC(TA=25℃) Parameter Symbol Test conditions Min. Typ. Max Unit Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA 4.90 5.0 5.10 V Output current IOUT VIN=VOUT+2.0V 300 -- -- mA Load regulation ΔVOUT VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Voltage drop Note2 VDIF IOUT=100mA -- 150 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Min. Typ. Max Unit Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V VIN=VOUT+2.0V, IOUT=10mA, PJ73AL90SC(TA=25℃) Parameter Symbol Test conditions Output voltage VOUT VIN=VOUT+2.0V, IOUT=10mA 8.82 9.0 9.18 V Output current IOUT VIN=VOUT+2.0V 300 -- -- mA Load regulation ΔVOUT VIN=VOUT+2.0V 1mA≤IOUT≤300mA -- 37 100 mV Voltage drop Note2 VDIF IOUT=100mA -- 130 300 mV Quiescent Current IQ No Load -- 1.5 3.0 μA VOUT+2.0V≤VIN≤20V,IOUT=1mA -- -- 0.2 %/V -- -- -- 20 V -- 100 -- ppm/℃ -- 400 -- mA Line regulation ΔVOUT / VOUT× ΔVIN Input voltage VIN Temperature coefficient ΔVOUT /VOUT× ΔTA -40℃≤TA≤85℃ Short Current IShort VOUT=0V VIN=VOUT+2.0V, IOUT=10mA, Note: 2.The difference of input voltage and output voltage when input voltage falls down gradually till output voltage equals to 98% of www.pingjingsemi.com Revision:1.1 Oct-2019 rating VOUT . 7 / 11 PJ73ALXXSC Series Low Dropout Regulators Basic Circuits VIN VIN C 1 10μF C o m m o n www.pingjingsemi.com Revision:1.1 Oct-2019 PJ73ALXXSC Series VOUT VOUT C 2 G N D 10μF Single Point GND C o m m o n 8 / 11 PJ73ALXXSC Series Low Dropout Regulators Package Outline SOT-23-3 Dimensions in mm 2.8 1.6 10 12 0.95 0.35 0.127± 0.03 ± 0.01 A ±0.1 ±0.05 2.92 ± 0.05 R0.15MAX `4X R0.15MAX `4X 1.26MAX 0.06 12 ± 0.05 ± 0.03 0.65 1.1 ± 0.05 10 Ordering Information Device Package Shipping PJ73ALXXSC SOT-23-3 3000PCS/Reel&Tape www.pingjingsemi.com Revision:1.1 Oct-2019 9 / 11 PJ73ALXXSC Series Low Dropout Regulators Conditions of Soldering Recommended condition of reflow soldering  Recommended peak temperature is over 245 OC. If peak temperature is below 245 OC, you may adjust the following parameters:  Time length of peak temperature (longer)  Time length of soldering (longer)  Thickness of solder paste (thicker)  Conditions of hand soldering  Temperature: 370 OC  Time: 3s max.  Times: one time   Storage conditions Temperature 5 to 40 OC  Humidity 30 to 80% RH  Recommended period One year after manufacturing www.pingjingsemi.com Revision:1.1 Oct-2019 10 / 11 PJ73ALXXSC Series Low Dropout Regulators Package Specifications 3,000 pcs per reel Cover Tape SOT-23-3 Carrier Tape 24,000 pcs per box 8 reels per box 18 5 104 120,000 pcs per carton 5 boxes per carton 185 2. Tape and reel data(7inch Units:mm) D A 3000 T2 T1 2900 2000 1900 1000 600 B C E PS F 1.10±0.10 Pin1 Revision:1.1 Oct-2019 N 3.2±0.10(Bo) 8 MAX 0.75 1.40±0.10(Ko) B-B Tape (8mm) www.pingjingsemi.com 0.46 0.2 8 MAX B 4.00±0.10 0.25±0.02(T) 2.45 1.55±0.05 3.50±0.05 2.00±0.05 8 ± 0 .1 0 4.00±0.10 B 1.75±0.10 Reel (7'') Symbol A B C E F D T1 T2 N G Value (unit: mm) Ø 177.8±1 2.7±0.2 Ø 13.5±0.2 Ø 54.5±0.2 12.3±0.3 9.6+2/-0.3 1.0±0.2 1.2±0.2 3.15±0.1 1.22±0.1 11 / 11
PJ73AL36SC 价格&库存
很抱歉,暂时无法提供与“PJ73AL36SC”相匹配的价格&库存,您可以联系我们找货
PJ73AL36SC
  • 5+0.56916
  • 50+0.44993
  • 150+0.39032
  • 500+0.34560
库存:1515
