PJ71K50SA
PJ71K50SA
    PJ(平晶)
    SOT-23
    输出类型:固定 输出极性:正 输出通道数:1 最大输入电压:24V 输出电压:5V
PJ71K50SA 数据手册
PJ71KXXSA Series Low Dropout Regulators Features  Low power consumption  Low voltage drop  Low temperature coefficient  High input voltage (up to 24V) SOT-23 Applications  Battery-powered equipment  Communication equipment  Audio/Video equipment 1.GND 2.VOUT 3.VIN Block Diagram General Description The PJ71KXXSA series is a set of three-terminal low power high voltage regulators implemented in CMOS technology. They allow input voltages as high as 24V. They are available with several fixed output voltages ranging from 3.0V to 5.0V. CMOS technology ensures low voltage drop and low quiescent current. VIN VOUT Vref GND Although designed primarily as fixed voltage regulators, these devices can be used with external components to obtain variable voltages and currents. Selection Table www.pingjingsemi.com Revision:1.1 Oct-2019 Part No. Output Voltage Tolerance PJ71K30SA 3.0V ± 5% PJ71K33SA 3.3V ± 5% PJ71K36SA 3.6V ± 5% PJ71K44SA 4.4V ± 5% PJ71K50SA 5.0V ± 5% 1/7 PJ71KXXSA Series Low Dropout Regulators Absolute Maximum Ratings (Ta=25℃ unless otherwise specified) Note1 Symbol Parameter Units Rating VIN Supply Voltage PD Power Dissipation 200 mW TOPR Operating Ambient -40 ~ +85 °C TSTG Storage Temperature -65 ~ +125 °C -0.3V to 28V V Note1: These are stress ratings only. Stresses exceeding the range specified under Absolute Maximum Ratings may cause substantial damage to the device. Functional operation of this device at other conditions beyond those listed in the specification is not implied and prolonged exposure to extreme conditions may affect device reliability. Electrical Characteristics PJ71K30SA (Ta=25℃) Symbol Parameter VOUT Test Conditions VIN Conditions Output Voltage 5V IOUT=10mA IOUT Output Current 5V △VOUT Load Regulation 5V VD Voltage Drop Note2 Current Consumption ISS △VOUT VIN Input Voltage △VOUT △Ta Temperature Coefficient Typ. Max. Units 2.85 3.0 3.15 V 100 mV 20 30 1mA≤IOUT≤20mA 60 IOUT=1mA 100 No load 4 VOUT+2V≤VIN≤24V Line Regulation △VIN×VOUT PJ71K33SA 5V Min. mA mV 6.0 %/V 0.2 IOUT=1mA 24 5V IOUT=10mA V mV/℃ ±0.45 0℃
PJ71K50SA 价格&库存
很抱歉,暂时无法提供与“PJ71K50SA”相匹配的价格&库存,您可以联系我们找货
