QUARTZ CRYSTAL UNIT
SERIES 7U, SEAM SEALED CERAMIC3.2*2.5MM SURFACE MOUNT PACKAGE
深圳市晶科鑫实业有限公司
Shenzhen Crystal Technology Industrial Co., Ltd
APPROVAL SHEET
CUSTOMER P/N:
TYPE:
DESCRIPTION:
P N/ SJK:
SMD CRYSTAL
SMD3225
MSL:
10PF
±10PPM
-40~85℃
□PAHS
□other
7U25000E10UCG
ENVIRONMENTAL: ■RoHS
REVISION:
25.000MHZ
A1
■REACH
■HF
2017-5-10
MOQ:
3000pcs/real
Levels 1
SIGNATURE
SUPPLIER
Issue
Check
CUSTOMER
Approve
QA
SJK
Signature
FAE_EMAIL
Date
Date
Check
Approve: □accept
Approve
□unaccepted
Note:
Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718
http://www.q-crystal.com
ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen
1 /4
QUARTZ CRYSTAL UNIT
1. TESTING CONDITION
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making
measurement
and tests are as follow:
Ambient temperature : 25±5℃
Relative humidity : 40%~70%
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
2. ELECTRICAL SPECIFICATIONS
Output Frequency Range
25.000000MHz
Mode
AT/Fundamental
Frequency Tolerance
±10 ppm max
Load Capacitance(C L )
10.0 PF
(at 25°C)
±10ppm max /
Frequency Stability Over Operating
-20 °C to +70 °C
Temperature Characteristics
±30ppm max/
-40 °C to +85 °C
Operating Temperature Range
-40 °C to +85 °C
Storage Temperature Range
-40 °C to +125 °C
Shunt Capacitance (C 0 )
3.0 PF Max
Driver Level (Typical)
10µW
Equivalent Series Resistance(ESR)
40Ω Max
Aging @25°C 1st year (Max)
±3ppm/year
2 /4
QUARTZ CRYSTAL UNIT
3. DIMENSION (Units: mm)
4. MARKING
5. REFLOW CONDITION
3 /4
QUARTZ CRYSTAL UNIT
6. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF.DOC
1.1
Drop Test
150 cm height, 3 times on concrete floor.
JIS C6701
1.2
Mechanical
Shock
1.3
Vibration
1.4
Gross Leak
Standard Sample For Automatic
Detector, Test Pressure: 2Kg / cm2
1.5
Fine Leak
Helium Bombing 4.5 Kg/ cm2 for 2 hr
1.6
Solder ability
Device are shocked to half sine wave ( 1000 G )
three mutually perpendicular axes each 3 times.
0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
(Total test time 12 hours)
Temperature
Immersing depth
Immersion time
Flux
Gross
Leak
245 ℃ ± 5℃
0.5 mm minimum
5 ± 1 seconds
Rosin resin methyl alcohol
solvent ( 1 : 4 )
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
2.Environmental Endurance
No.
Test Item
Test Methods
2.1
Resistance
To
Soldering Heat
Pre-heat temperature
Pre-heat time 60 ~
Test temperature
Test time
2.2
2.3
High
Temp. Storage
Low
Temp.
Storage
REF.DOC
125 ℃
120 sec.
260 ± 5 ℃
10 ± 1 sec.
MIL-STD-202F
+ 125 ℃ ± 3 ℃ for 500 ± 12 hours
MIL-STD-883E
- 40 ℃ ± 3 ℃ for 500 ± 12 hours
MIL-STD-883E
Total 100 cycles of the following temperature cycle
2.4
2.5
2.6
Thermal Shock
High Temp
&Humidity
Pressure
Cooker Storage
MIL-STD-883E
85℃ ± 3℃, RH 85% , 500Hrs
JIS C5023
121 ± 3℃ , RH100% , 2 bar , 240Hrs
JIS C6701
4 /4
很抱歉,暂时无法提供与“7U25000E10UCG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.41777
- 100+0.39099
- 300+0.36421
- 500+0.33743
- 2000+0.32404
- 5000+0.31600
- 国内价格
- 5+0.54419
- 50+0.42618
- 150+0.36723
- 500+0.32300
- 3000+0.28762
- 6000+0.26985
