SS12~SS110
Surface Mount Schottky Rectifiers
Features
Low profile package
Ideal for automated placement
Ultrafast reverse recovery time
Low power losses, high efficiency
Low forward voltage drop
High surge capability
High temperature soldering:
260℃/10 seconds at terminals
Mechanical Date
Case: JEDEC DO-214AC molded plastic
body over glass passivated chip
Terminals: Solder plated, solderable per
J-STD-002B and JESD22-B102D
Major Ratings and Characteristics
IF(AV)
1.0A
VRRM
20 V to 100 V
IFSM
40A
VF
0.50V, 0.55V, 0.70V, 0.85V
Tj max.
125 °C
Maximum Ratings & Thermal Characteristics
(TA = 25 °C unless otherwise noted)
Items
Symbol SS12
SS13
SS14
SS15
SS16
60
SS18 SS110 UNIT
Maximum repetitive peak reverse voltage
VRRM
40
50
Maximum RMS voltage
VRMS
14
21
28
35
42
56
70
V
Maximum DC blocking voltage
VDC
40
50
60
80
100
V
Maximum average forward rectified current
IF(AV)
1.0
A
Peak forward surge current 8.3 ms single
half sine-wave superimposed on rated load
IFSM
40
A
Voltage rate of change (rated VR)
dv/dt
10000
V/µs
RθJL
35
℃/W
–65 to +125
Thermal resistance from junction to lead
(1)
Operating junction and storage temperature
TJ,TSTG
range
80
100
V
Note 1: Mounted on P.C.B. with 0.2 x 0.2” (5.0 x 5.0mm) copper pad areas.
Electrical Characteristics
Items
Instantaneous forward
voltage
Reverse current
Test conditions
Symbol
SS12
SS13~14
SS15~16
SS18~110
UNIT
IF=1.0A(2)
VF
0.50
0.55
0.70
0.85
V
VR=VDC
TA=25℃
TA=100℃
IR
Note 2: Pulse test:300μs pulse width,1% duty cycle.
www.slkormicro.com
1
0.5
5
mA
SS12~SS110
Characteristic Curves (TA=25 ℃ unless otherwise noted)
www.slkormicro.com
2
很抱歉,暂时无法提供与“SS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12998
- 400+0.10732
- 800+0.10571
- 2000+0.07007
- 国内价格
- 50+0.14180
- 500+0.11708
- 2000+0.07645
- 4000+0.06823
- 24000+0.06105
- 50000+0.05725
- 国内价格
- 1+0.13640
- 50+0.06842
- 2000+0.05181
