6BS08000F20UCG
6BS08000F20UCG
    SJK(晶科鑫)
    HC49S
    无源晶振 8MHz ±20ppm 20pF -40℃~+85℃
6BS08000F20UCG 数据手册
QUARTZ CRYSTAL UNIT SERIES 6BS/SS, Resistance Welded HC-49S Package 深圳市晶科鑫实业有限公司 Shenzhen Crystal Technology Industrial Co., Ltd APPROVAL SHEET CUSTOMER P/N: TYPE: DESCRIPTION: P N/ SJK: 49S DIP CRYSTAL 49S 8.000MHZ MSL: -40~85℃ 6BS08000F20UCG ENVIRONMENTAL: ■RoHS REVISION: 20PF ±20PPM A1 ■REACH ■HF □PAHS 2014-6-10 □other MOQ: 1000pcs Levels 1 SIGNATURE SUPPLIER Issue Check CUSTOMER Approve QA SJK Signature FAE_EMAIL Date Date Check Approve: □accept Approve □unaccepted Note: Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 1 /4 QUARTZ CRYSTAL UNIT SERIES 6BS/SS, Resistance Welded HC-49S Package 1. FEATURE ⚫ ⚫ ⚫ ⚫ ⚫ Leadless type High precision characteristic covering up to high frequency range Designed for automatic mounting and reflow soldering Embossed taping specification The best choice of Bluetooth wireless communication sets, DSN, PDA and mobile phone 2. ELECTRICAL SPECIFICATIONS Output Frequency Range 8.000MHz Mode AT/Fundamental Frequency Tolerance ±20 ppm max Load Capacitance(CL) 20.0 PF Frequency Stability Over Operating Temperature Characteristics (at 25°C) ±30ppm max Operating Temperature Range -40 °C to +85 °C Storage Temperature Range -40 °C to +125 °C Shunt Capacitance (C0) 3.0 PF Max Driver Level (Typical) 100µW Equivalent Series Resistance(ESR) 60Ω Max Aging @25°C 1st year (Max) ±3ppm/year Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 2 /4 QUARTZ CRYSTAL UNIT SERIES 6BS/SS, Resistance Welded HC-49S Package 3. DIMENSION (Units: mm) 4. MARKING SJK XX.XXX 5. REFLOW CONDITION / 回流焊 Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 3 /4 QUARTZ CRYSTAL UNIT SERIES 6BS/SS, Resistance Welded HC-49S Package 6. RELIABILITY TEST SPECIFICATION 1.Mechanical Endurance No. 1.1 Test Item Drop Test 1.2 Mechanical Shock 1.3 Vibration 1.4 Gross Leak 1.5 Fine Leak 1.6 Solder ability Test Methods 150 cm height, 3 times on concrete floor. Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minute Perpendicular axes each test time 4 hours (Total test time 12 hours) Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2Kg / cm2 Helium Bombing 4.5 Kg/ cm2 for 2 hr Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol solvent ( 1 : 4 ) REF.DOC JIS C6701 MIL-STD-202F MIL-STD-883E MIL-STD-883E MIL-STD-883E MIL-STD-883E 2.Environmental Endurance No. Test Item Test Methods 2.1 Resistance To Soldering Heat Pre-heat temperature Pre-heat time 60 ~ Test temperature Test time 2.2 2.3 High Temp. Storage Low Temp. Storage REF.DOC 125 ℃ 120 sec. 260 ± 5 ℃ 10 ± 1 sec. MIL-STD-202F + 125 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E - 40 ℃ ± 3 ℃ for 500 ± 12 hours MIL-STD-883E Total 100 cycles of the following temperature cycle 2.4 2.5 2.6 Thermal Shock High Temp &Humidity Pressure Cooker Storage MIL-STD-883E 85℃ ± 3℃, RH 85% , 500Hrs JIS C5023 121 ± 3℃ , RH100% , 2 bar , 240Hrs JIS C6701 Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718 http://www.q-crystal.com ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen 4 /4
6BS08000F20UCG
物料型号为6BS08000F20UCG,属于49S DIP晶体系列。
器件简介包括无铅类型、高精度特性覆盖高频范围、设计用于自动贴装和回流焊接、压纹胶带规格,是蓝牙无线通信设备、DSN、PDA和手机的最佳选择。
引脚分配信息未在文档中明确列出,但根据49S DIP晶体的通用布局,通常有4个引脚,两个用于固定晶体,另外两个用于电气连接。
参数特性包括输出频率范围为8.000MHz,模式为AT/基本模式,频率容差为±20ppm最大(在25°C时),负载电容为20.0PF,频率稳定性在操作温度范围内为±30ppm最大,操作温度范围为-40°C至+85°C,存储温度范围为-40°C至+125°C,并联电容最大为3.0PF,驱动电平典型值为100mW,等效串联电阻(ESR)最大为60欧姆,25°C下第一年老化最大为±3ppm/年。
功能详解涉及电气规格和可靠性测试规范,包括机械耐久性测试和环境耐久性测试,如跌落测试、机械冲击、振动、泄漏测试、焊接能力、耐焊热性、高温存储、低温存储、热冲击、高温高湿、压力锅存储等。
封装信息包括尺寸图,显示了晶体的顶部视图、侧视图和底部视图,以及标记信息,晶体上标记为"SJK XX.XXX"。
回流焊条件也提供,包括预热、主要加热和峰值温度及时间。
6BS08000F20UCG 价格&库存
很抱歉,暂时无法提供与“6BS08000F20UCG”相匹配的价格&库存,您可以联系我们找货
6BS08000F20UCG
  • 5+0.65502
  • 50+0.51506
  • 200+0.44799
  • 400+0.39550
  • 2000+0.35360
  • 5000+0.33254
库存:9890
6BS08000F20UCG
  • 1+0.29870
库存:10
6BS08000F20UCG
  • 1+0.418501+0.05430
库存:90
6BS08000F20UCG
  • 1+0.51318
库存:1
