2N12288G33YC
2N12288G33YC
    SJK(晶科鑫)
    SMD2520_4P
    有源晶振 3.3V 12.288MHz SMD2520_4P
2N12288G33YC 数据手册
CRYSTAL OSCILLATOR SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE 深圳市晶科鑫实业有限公司 样品承认书 客户代码: 物料名称: 贴片钟振 规格型号: SMD2520 OSC 12.288MHZ 1.8~3.3V ±30PPM LVCMOS -40~85℃ P N/ SJK: 2N12288G33YC 环保属性: ■RoHS 版 A1 次: 湿敏等级: ■REACH 制定 □其它 一级 应 商 承 审 核 贺丹斌 认 签 认 章 ( 核 准 工 程 师 )公 司 承 认 审 核 批 准 黄灏东 SJK 支持 18682088994 (Mr.黄) FAE_EMAIL sjk-fae@q-caystal.com 日 □PAHS 2017-5-10 初版 承 供 ■HF 盖章签署 日 期 期 备注: 电话:0755-88352810-837(Mr.huang) 传真:0755-88353718 http://www.q-crystal.com 公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室 1 /6 Downloaded From Oneyac.com CRYSTAL OSCILLATOR SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE 1. ELECTRICAL SPECIFICATIONS Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as follow: Ambient temperature : 25±5℃ Relative humidity : 40%~70% If there is any doubt about the results, measurement shall be made within the following limits: Ambient temperature : 25±3℃ Relative humidity : 40%~70% Measure equipment Electrical characteristics measured by MD 37WX-05M or equivalent. Crystal cutting type The crystal is using AT CUT (thickness shear mode). Parameters 1 2 SYM Electrical Spec. MIN Nominal Frequency Frequency Stability TYPE MAX Notes UNITS 12.288000 MHZ AT 25℃ ±10 PPM Over Operating Temperature range ±20 PPM 3 Operating Temperature Topr -40 25 85 ℃ 4 Storage Temperature Tstg -55 ~ 125 ℃ 5 Supply Voltage VDD 6 Input Current Icc 7 Enable Control 8 Output Load : CMOS 1.8~3.3 / ±10% 5 1.62~3.63 available V mA Yes CL Pad1 15 90% Vdd pF 9 Output Voltage High VoH 10 Output Voltage Low VoL 10% Vdd V 11 Rise Time Tr 5 ns 12 Fall Time Tf 5 ns 13 Symmetry (Duty ratio) TH/T 55 % 14 Start-up Time Tosc 10 ms 15 Enable Voltage High Vhi 16 Disable Voltage Low Vlo 17 Aging 18 Output Disable Delay Time T off 150 us 19 Output Enable Delay Time T on 150 us 20 Phase Jitter (12KHZ~20MHZ) 1.0 ps 45 V ~ 70% Vdd 10%→90%VDD Level 90%→10%VDD Level V 30% Vdd ±3 0.5 V ppm/yr. 1st. Year at 25℃ 电话:0755-88352810-837(Mr.huang) 传真:0755-88353718 http://www.q-crystal.com 公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室 2 /6 Downloaded From Oneyac.com CRYSTAL OSCILLATOR SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE 2. DIMENSIONS (Units :mm) 3. MARKING 4. TEST CIRCUIT Control input (output enable/disable) Logic 1 or open on pad 1: Oscillator output Logic 0 on pad 1 : Disable output to high impedance 5. WAVEFORM CONDITIONS Waveform measurement system should have a min. bandwidth of 5 times the frequency being tested. 电话:0755-88352810-837(Mr.huang) 传真:0755-88353718 http://www.q-crystal.com 公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室 3 /6 Downloaded From Oneyac.com CRYSTAL OSCILLATOR SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE 6. OUTPUT ENABLE / DISABLE DELAY The following figure shows the oscillator timing during normal operation . Note that when the device is in standby, the oscillator stops. When standby is released, the oscillator starts and stable oscillator output occurs after a short delay 7. SUGGESTED REFLOW PROFILE Total time : 200 sec. Max / Solder melting point :220 ℃ 8. STRUCTURE ILLUSTRATION 电话:0755-88352810-837(Mr.huang) 传真:0755-88353718 http://www.q-crystal.com 公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室 4 /6 Downloaded From Oneyac.com CRYSTAL OSCILLATOR SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE NO COMPONENTS MATERIALS FINISH/SPECIFICATIONS 1 LID Kovar (Fe/Co/Ni) 2 Base(Package) Ceramic (AI2O3) + Kovar (Fe/Co/Ni)+ Ag/Cu Color black 3 PAD Au Tungsten metalize + Ni plating + Au plating 4 Crystal blank SiO2 5 Conductive adhesive Ag 6 Electrode Noble Metal 7 IC chip 8 Bonding wire Au Pad 1 options : NC is 5 wires , EN is 6 wires. 9 Die attached Conductive (Ag) Epoxy resin Silicon resin 9. RELIABILITY TEST SPECIFICATION 1.Mechanical Endurance No. Test Item Test Methods REF. DOC 1 Drop Test 75 cm height,3 times on concrete floor . JIS C6701 Device are shocked to half sine wave ( 1000 G ) three mutually perpendicular axes each 3 times. 0.5m sec. duration time Frequency range 10 ~ 2000 Hz Amplitude 1.52 mm/20G Sweep time 20 minutes Perpendicular axes each test time 4 Hrs (Total test time 12 Hrs) Standard Sample For Automatic Gross Leak Detector, Test Pressure: 2kg / cm2 2 Mechanical Shock 3 Vibration 4 Gross Leak 5 Fine Leak Helium Bomging 4.5 kgf / cm 2 for 2 Hrs Solderability Temperature 245 ℃ ± 5℃ Immersing depth 0.5 mm minimum Immersion time 5 ± 1 seconds Flux Rosin resin methyl alcohol solvent ( 1 : 4 ) 6 2.Environmental Endurance MIL-STD-202F MIL-STD-883E MIL-STD-883E MIL-STD-883E No. Test Item Test Methods REF. DOC 1 Resistance To Soldering Heat Pre-heat temperature 125 ℃ Pre-heat time 60 ~ 120 sec. Test temperature 260 ± 5 ℃ MIL-STD-202F 电话:0755-88352810-837(Mr.huang) 传真:0755-88353718 http://www.q-crystal.com 公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室 5 /6 Downloaded From Oneyac.com CRYSTAL OSCILLATOR SERIES 2N, SEAM SEALED CERAMIC 2.5X2.0MM SURFACE MOUNT PACKAGE Test time 10 ± 1 sec. 2 3 4 5 6 High Temp. Storage Low Temp. Storage + 125 ℃ ± 3 ℃ for 1000 ± 12 Hrs - 40 ℃ ± 3 ℃ for 1000 ± 12 Hrs MIL-STD-883E Total 100 cycles of the following temperature cycle Thermal Shock MIL-STD-883E Pressure Cooker Storage High Temp& Humidity 121 ± 3℃ , RH100% , 2 bar , 240 Hrs JIS C6701 85℃ ± 3℃, RH 85% , 1000 Hrs JIS C5023 备注 电话:0755-88352810-837(Mr.huang) 传真:0755-88353718 http://www.q-crystal.com 公司地址: 深圳市龙岗区天安云谷产业园一期 3 栋 C 座 12 楼 1204~1206 室 6 /6 Downloaded From Oneyac.com 单击下面可查看定价,库存,交付和生命周期等信息 >>SJK(晶科鑫) Downloaded From Oneyac.com
2N12288G33YC
物料型号:SMD2520 OSC 12.288MHZ 1.8~3.3V ±30PPM LVCMOS -40~85℃ P N/ SJK: 2N12288G33YC
器件简介:文档描述了一种贴片钟振,属于CRYSTAL OSCILLATOR SERIES 2N,采用密封陶瓷2.5X2.0MM表面贴装封装。
引脚分配:文档中提到Pad 1用于使能控制,具体为Logic 1或悬空时振荡器输出,Logic 0时关闭输出至高阻态。
参数特性:包括工作频率12.288MHZ,频率稳定性在25℃时±10PPM,整个工作温度范围内±20PPM,工作温度-40~85℃,存储温度-55~125℃,供电电压1.8~3.3V,输入电流5mA等。
功能详解:文档提供了振荡器的测试电路、波形条件、输出使能/禁用延迟、回流焊接曲线、结构图等信息。
应用信息:文档未明确提供应用信息,但根据物料型号参数特性,可以推断该振荡器适用于需要精确时钟信号的电子设备。
封装信息:封装类型为表面贴装,尺寸为2.5X2.0MM。
2N12288G33YC 价格&库存
很抱歉,暂时无法提供与“2N12288G33YC”相匹配的价格&库存,您可以联系我们找货
