XD3403
XD3403
    XINLUDA(信路达)
    DIP16
    XD3403 是一款低成本、具备真正差分输入的四运放。在单电源应用中,XD3403 相较于标准运算放大器类型具有若干明显优势。该四运放可在低至 3V 的电源电压下工作
XD3403 数据手册
XD3403 DIP-14 XL3403 SOP-14 D D D D D D Wide Range of Supply Voltages, Single Supply . . . 3 V to 36 V or Dual Supplies Class AB Output Stage True Differential Input Stage Low Input Bias Current Internal Frequency Compensation Short-Circuit Protection (TOP VIEW) 1OUT 1IN– 1IN+ VCC+ 2IN+ 2IN– 2OUT 1 14 2 13 3 12 4 11 5 10 6 9 7 8 4OUT 4IN– 4IN+ VCC– 3IN+ 3IN– 3OUT description XDXL3403 quadruple operational amplifiers similar in performance to the XD741, but with several distinct advantages. They are designed to operate from a single supply over a range of voltages from 3 V to 36 V. Operation from split supplies also is possible, provided the difference between the two supplies is 3 V to 36 V. The common-mode input range includes the negative supply. Output range is from the negative supply to VCC – 1.5 V. Quiescent supply currents are less than one-half those of the XD741. and the XDXL3403 is characterized for operation from 0°C to 70°C. logic diagram (each amplifier) IN+ + IN– – OUT 1 XD3403 DIP-14 XL3403 SOP-14 schematic (each amplifier) Common Bias Circuitry VCC+ 5 pF IN+ To Three Other Amplifiers Output IN– 2.4 kΩ VCC– Component values shown are nominal. absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage (see Note 1): VCC+ . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 V VCC– . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –18 V Supply voltage, VCC+ with respect to VCC– . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 36 V Differential input voltage (see Note 2) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±36 V Input voltage (see Notes 1 and 3) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±18 V Package thermal impedance, θJA (see Note 4): 3403 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80°C/W Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260°C Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTES: 1. These voltage values are with respect to the midpoint between VCC+ and VCC–. 2. Differential voltages are at IN+ with respect to IN–. 3. Neither input must ever be more positive than VCC+ or more negative than VCC–. 4. The package thermal impedance is calculated in accordance with JESD 51-7. 2 XD3403 DIP-14 XL3403 SOP-14 recommended operating conditions VCC TA Supply voltage Dual supply voltage Dual-supply VCC+ VCC– Operating free-air free air temperature XDXL3403 MIN MAX 5 30 UNIT V 2.5 15 V –2.5 –15 V 0 70 °C electrical characteristics at specified free-air temperature, VCC+ = 14 V, VCC– = 0 V for VCC± = ±15 V for XDXL3403 (unless otherwise noted) PARAMETER VIO Input offset voltage See Note 5 aV Temperature coefficient of input offset voltage See Note 5 IIO Input offset current See Note 5 aI Temperature coefficient of input offset current See Note 5 IIB Input bias current See Note 5 VICR Common-mode input voltage range‡ VOM Peak P k output t t voltage swing IO IO XDXL3403 TEST CONDITIONS† MIN 25°C TYP MAX 2 10 Full range 12 Full range 10 25°C 30 Full range 25°C –0.2 VCC– to 13 VCC– to 13.5 25°C ±12 ±13.5 RL = 2 kΩ 25°C ±10 ±13 RL = 2 kΩ Full range ±10 25°C 20 Full range 15 AVD Large-signal differential g g voltage amplification V RL = 2 kΩ VO = ±10 V, BOM Maximum-output-swing bandwidth VOPP = 20 V, AVD = 1, THD ≤ 5%, RL = 2 kΩ B1 φm Unity-gain bandwidth ri nA pA/C –0.5 –0.8 25°C RL = 10 kΩ 50 50 Full range mV µV/°C 200 Full range UNIT µA V V 200 V/mV 25°C 9 kHz 25°C 1 MHz Phase margin VO = 50 mV, RL = 10 kΩ CL = 200 pF, RL = 2 kΩ Input resistance f = 20 Hz 25°C ro Output resistance f = 20 Hz 25°C CMRR Common-mode rejection ratio VIC = VICRmin 25°C kSVS Supply voltage sensitivity (∆VIO/∆VCC) VCC± = ±2.5 to ±15 V 25°C IOS Short-circuit output current§ 25°C 25°C 60° 0.3 70 ±10 1 MΩ 75 Ω 90 dB 30 150 µV/V ±30 ±45 mA ICC Total supply current No load, See Note 5 25°C 2.8 7 mA † All characteristics are measured under open-loop conditions with zero common-mode voltage unless otherwise specified. Full range for TA is 0°C to 70°C for XDXL3403. ‡ The VICR limits are linked directly, volt-for-volt, to supply voltage; the positive limit is 2 V less than VCC+. § Temperature and/or supply voltages must be limited to ensure that the dissipation rating is not exceeded. NOTE 5: VIO, IIO, IIB, and ICC are defined at VOXDXL3403. 3 3 XD3403 DIP-14 XL3403 SOP-14 electrical characteristics, VCC+ = 5 V, VCC– = 0 V, TA = 25°C (unless otherwise noted) XDXL3403 TEST CONDITIONS† PARAMETER MIN VIO IIO Input offset voltage IIB Input bias current VO = 2.5 V RL = 10 kΩ VOM Peak output voltage swing‡ RL = 10 kΩ, VCC+ = 5 V to 30 V AVD Large-signal g g differential voltage amplification VO = 1.7 1 7 V to 3.3 3 3 V, V RL = 2 kΩ kSVS Supply-voltage y g sensitivity y (∆VIO/∆VCC±) ±2 5 V to ±15 V VCC± = ±2.5 Supply current VO = 2.5 V, No load f = 1 kHZ to 20 kHZ ICC VO1/VO2 VO = 2.5 V VO = 2.5 V Input offset current Crosstalk attenuation 3.3 TYP MAX UNIT 2 10 30 50 mV nA –0.2 –0.5 µA 3.5 V V CC+ – 1.7 20 200 V/mV 150 2.5 7 µV/V mA 120 dB † All characteristics are measured under open-loop conditions with zero common-mode input voltage unless otherwise specified. ‡ Output will swing essentially to ground. operating characteristics, VCC± = ±15 V for XDXL3403, TA = 25°C, AVD = 1 (unless otherwise noted) PARAMETER TYP UNIT VI = ±10 V, ∆VO = 50 mV, CL = 100 pF, RL = 2 kΩ, See Figure 1 0.6 V/µs CL = 100 pF, RL = 10 kΩ, See Figure 1 0.35 µs CL = 100 pF, RL = 10 kΩ, See Figure 1 0.35 µs Overshoot factor ∆VO = 50 mV, ∆VO = 50 mV, CL = 100 pF, RL = 10 kΩ, See Figure 1 20 % Crossover distortion VI(PP) = 30 mV, VOPP = 2 V, f = 10 kHZ 1 % tr tf Rise time Fall time TEST CONDITIONS PARAMETER MEASUREMENT INFORMATION OUT VI + Slew rate at unity gain – SR RL CL = 100 pF Figure 1. Unity-Gain Amplifier 4 XD3403 DIP-14 XL3403 SOP-14 TYPICAL CHARACTERISTICS† 30 ÎÎÎÎ ÎÎÎÎ ÎÎÎÎ RL = 10 kΩ TA = 25°C 25 20 15 10 5 0 0 2 MAXIMUM PEAK-TO-PEAK OUTPUT VOLTAGE vs FREQUENCY VOPP – Maximum Peak-to-Peak Output Voltage – V VOPP – Maximum Peak-to-Peak Output Voltage – V MAXIMUM PEAK-TO-PEAK OUTPUT VOLTAGE vs SUPPLY VOLTAGE 4 6 8 10 12 14 16 30 25 20 15 ÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎ 10 5 VCC± = ±15 V CL = 0 RL = 10 kΩ TA = 25°C See Figure 1 0 1k 10 k 100 k f – Frequency – Hz |VCC±| – Supply Voltage – V Figure 3 LARGE-SIGNAL DIFFERENTIAL VOLTAGE AMPLIFICATION vs FREQUENCY VOLTAGE-FOLLOWER LARGE-SIGNAL PULSE RESPONSE ÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎ ÎÎÎÎÎ VCC± = ±15 V RL = 2 kΩ TA = 25°C See Figure 1 10 105 Output Input Output Voltages – V A VD – Large-Signal Differential Voltage Amplification – dB Figure 2 106 104 103 102 ÎÎÎÎÎ ÎÎÎÎÎ VCC± = ±15 V RL = 2 kΩ TA = 25°C 10 1 1 10 100 1M 5 0 –5 Input –10 1k 10 k 100 k 1M f – Frequency – Hz 0 10 20 30 40 50 60 70 80 90 t – Time –µs Figure 4 Figure 5 † Operation of the device at these or any other conditions beyond those indicated under ‘‘recommended operating conditions” is not implied. 5 XD3403 DIP-14 XL3403 SOP-14 TYPICAL CHARACTERISTICS† INPUT BIAS CURRENT vs SUPPLY VOLTAGE INPUT BIAS CURRENT vs FREE-AIR TEMPERATURE ÎÎÎÎÎ ÎÎÎÎÎ 250 VCC± = ±15 V 200 150 100 50 0 –75 ÎÎÎÎ ÎÎÎÎ TA = 25°C I IB – Input Bias Current – mA I IB – Input Bias Current – mA 250 200 150 100 50 0 –50 –25 0 25 50 75 100 0 125 TA – Free-Air Temperature – °C 2 4 6 8 10 12 14 16 |VCC±| – Supply Voltage – V Figure 6 Figure 7 † Operation of the device at these or any other conditions beyond those indicated under ‘‘recommended operating conditions” is not implied. 6 XD3403 DIP-14 XL3403 SOP-14 SOP-14 7 XD3403 DIP-14 XL3403 SOP-14 8
XD3403 价格&库存
很抱歉,暂时无法提供与“XD3403”相匹配的价格&库存,您可以联系我们找货
