XL17358 SOP-8
XD17358 DIP-8
Description
XDXL/17358 series are dual operational amplifier that provide high gain and internal phase compensation,
with single power supply. They can be widely applied to control equipments and to general use.
Features
• Wide range of supply voltage, and single power supply used
• Wide range of common mode voltage, and possible to operate with an input about 0 V, and output
around 0 V is available
• Frequency characteristics and input bias current are temperature compensated
• Low electro-magnetic susceptibility level
Measurement Condition
Output Offset Voltage vs. Input Interference
5.0
Rs
Rs
Rf
0.01 µ
Vin
−10 dBm
RF signal source
(for quasi-RF noise)
Vout
V
_ (= 100∗Vio)
Output offset voltage (arb. unit)
Rf
Vcc = +7.5 V
Vee = −7.5 V
4.0
XDXL/17358 series
3.0
2.0
Improvement
1.0
XDXL/17358 series
−1.0
100E+3
1
1E+6
10E+6
100E+6
1E+9
Input RF frequency (Hz)
10E+9
XL17358 SOP-8 XD17358 DIP-8
Pin Arrangement
Vout1
Vin(−)1
1
2
Vin(+)1
3
GND
4
1
2
8
VCC
7
Vout2
6
Vin(−)2
5
Vin(+)2
(Top View)
Circuit Schematic (1/2)
Q5
Vin(−)
Q1
Q2
Q3
Q4
Q6
C
Q7
R1
Vin(+)
Vout
Q11
Q10
Q8
Q9
2
Q13
Q12
Absolute Maximum Ratings
(Ta = 25°C)
Ratings
Item
Symbol
Supply voltage
VCC
Sink current
Isink
XDXL/17358
32
Unit
V
mA
50
1
Power dissipation
PT
570 *
Common mode input voltage
VCM
−0.3 to VCC
V
Differential input voltage
Vin (diff)
±VCC
V
Operating temperature
Topr
−40 to +85
°C
Storage temperature
Tstg
−55 to +125
°C
mW
Notes: 1. This is the allowable values up to Ta = 50°C. Derate by 8.3 mW/°C.
2. These are the allowable values up to Ta = 25°C mounting in air.
When it is mounted on glass epoxy board of 40 mm × 40 mm × 1.5 mmt with 30% wiring density,
the allowable value is 570 mW up to Ta = 45°C. If Ta > 45°C, derate by 7.14 mW/°C.
3
Electrical Characteristics
(VCC = +15 V, Ta = 25°C)
Item
Symbol
Min
Typ
Max
Unit
Test Conditions
Input offset voltage
VIO
3
7
mV
VCM = 7.5V, RS = 50Ω, Rf = 50kΩ
Input offset current
IIO
5
50
nA
VCM = 7.5V, IIO = | II (+) – II (–) |
Input bias current
IIB
30
250
nA
VCM = 7.5V
Power source rejection
ratio
PSRR
93
dB
RS = 1kΩ, Rf = 100kΩ
Voltage gain
AVD
75
90
dB
RL = ∞, RS = 1kΩ, Rf = 100kΩ
Common mode rejection
ratio
CMR
80
dB
RS = 50Ω, Rf = 5kΩ
Common mode input
voltage range
VCM (+)
13.5
V
VCM (–)
–0.3
V
RS = 1k•, Rf = 100kΩ
Peak-to-peak output
voltage
Vop-p
13.6
V
f = 100Hz, RL = 20kΩ, RS = 1kΩ,
Rf = 100kΩ
Output source current
Iosource
mA
VIN = 1V, VIN = 0V, VOH = 10V
Output sink current
Iosink
10
mA
VIN = 1V, VIN = 0V, VOL = 2.5V
Output sink current
Iosink
15
50
µA
VIN = 1V, VIN = 0V,
Vout = 200mV
Supply current
ICC
0.8
2
mA
VIN = GND, RL = ∞
Slew rate
SR
0.2
V/µs
RL = ∞, VCM = 7.5V, f = 1.5kHz
Channel separation
CS
120
dB
f = 1kHz
4
Input Bias Current vs. Ambient Temperature
Output Source Current vs. Ambient Temperature
80
VCC = 15 V
70
VOH = 10 V
60
80
Input bias current IIB (nA)
Output source current Iosource (mA)
Characteristic Curves
50
40
30
−20
60
Ambeint temperature Ta (°C)
VCC = 15 V
VCM = 7.5 V
70
60
50
40
30
−20
80
Ta = 25°C
Supply current ICC (mA)
80
3
2
1
16
24
32
Supply voltage VCC (V)
40
Maximum output voltage VOP-P (V)
Voltage gain AVD (dB)
8
16
24
32
40
Maxlmum Output Voltage vs. Frequency
160
Ta = 25°C
RL = ∞
120
80
40
8
16
24
32
Ta = 25°C
60
Voltage Gain vs. Supply Voltage
Input Bias Current vs. Supply Voltage
Supply Current vs. Supply Voltage
4
60
40
5
VCC = 15 V
Ta = 25°C
RL = 20 kΩ
16
12
8
4
1k
3k
10 k 30 k 100 k 300 k
Frequency f (Hz)
1M
Voltage Gain vs. Frequency
120
VCC = 15V
Ta = 25°C
RL = ∞
80
60
40
3
10
30
100
300
1k
3k
Frequency f (Hz)
10 k
30 k
100 k 300 k
Common Mode Rejection Ratio vs. Frequency
120
Common mode rejection ratio CMR (dB)
100
VCC = 15V
Ta = 25°C
RS = 50 Ω
100
80
60
40
300
1k
3 k 10 k 30 k
Frequency f (Hz)
6
100 k 300 k
1M
1M
Solder Mounting Method
1. Small and light surface-mount packages require spicial attentions on solder mounting.
On solder mounting, pre-heating before soldering is needed.
The following figure show an example of infrared rays refow.
Temperature
2. The difference of thermal expansion coefficeient between mounted substrates and IC leads may cause a
failure like solder peeling or soler wet, and electrical characteristics may change by thermal stress.
Therefore, mounting should be done after sufficient confirmation for especially in case of ceramic
substrates.
235°C Max
10 s Max
140 to 160°C
≅ 60 s
1 to 4°C/s
1 to 5°C/s
Time (s)
Figure 1 An Example of Infrared Rays Reflow Conditions
7
Package Dimensions
Unit: mm
6.3
7.4 Max
9.6
10.6 Max
8
5
1
0.89
4
1.3
7.62
0.5 Min
2.54 Min 5.06 Max
1.27 Max
+ 0.10
0.25 − 0.05
0.48 ± 0.10
2.54 ± 0.25
0° − 15°
Unit: mm
4.85
4.4
5.25 Max
5
8
1
2.03 Max
*0.22 ± 0.05
0.20 ± 0.04
4
0.75 Max
0.25
6.50 +– 0.15
1.05
1.27
*0.42 ± 0.08
0.40 ± 0.06
0.10 ± 0.10
0˚ – 8˚
0.25
0.60 +– 0.18
0.15
0.12 M
8
很抱歉,暂时无法提供与“XD17358”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.41869
- 50+1.07763
- 150+0.94889
- 500+0.78819
- 2000+0.71669
- 4000+0.67371
