RS1A-RS1M
Surface Mount Fast Switching Rectifier
Features
Low profile surface mounted package
Fast recovery time for high efficiency
Glass passivated junction
Plastic package has underwriters laboratory
flammability classification 94 V-O
• High temperature soldering: 250 °C / 10 seconds at terminals
• RoHS compliant
SMA
Maximum Ratings (T Ambient=25ºC unless noted)
Symbol
VRRM
VRMS
VDC
IAV
IFSM
Description
Maximum Recurrent
Peak Reverse
Voltage
Maximum RMS
Voltage
Maximum DC
Blocking Voltage
Maximum Average
Forward Rectified
Current
RS1A
RS1B
RS1D
RS1G
RS1J
RS1K
RS1M
Unit
50
100
200
400
600
800
1000
V
35
70
140
280
420
560
700
V
50
100
200
400
600
800
1000
V
1.0
Peak Forward Surge
Current
30
Note: Single phase half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
www.slkormicro.com
1
Conditions
A
TA=50°C
A
8.3ms single half sinewave superimposed on
rated load (JEDEC
method)
RS1A-RS1M
Electrical Characteristics (T Ambient=25ºC unless noted)
Symbol
VF
IR
Description
Typical Reverse
Recovery Time
CJ
Typical Junction
Capacitance
Rθ-JA
TJ,TSTG
RS1B
RS1D
RS1G
Maximum
Instantaneous
Forward Voltage
Maximum DC
Reverse Current at
Rated DC Blocking
Voltage
trr
Rθ-JL
RS1A
RS1J
RS1K
RS1M
1.3
Unit
Conditions
V
IF at 1.0 A
5
TA = 25 °C
µA
100
TA = 125 °C
150
250
10
32
Maximum Thermal
Resistance
Operating Junction
and Storage
Temperature Range
500
nS
7
pf
° C/W
105
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
Measured at 1.0 MHZ and
Applied Vr = 4.0 volts.
Mounted on 0.2" x 0.2"
(5mmx5mm) copper pad
area
-55 to 150
°C
For capacitive load, derate current by 20%.
IFSM Peak Forward Surge Current (A)
IAV Average Forward Rectified current (A)
Typical Characteristics Curves
Number of Cycles at 60Hz
Fig.2- Max. Non-Repetitive Forward Surge Current
Ambient Temperature (° C)
Fig.1- Forward Current Derating Curve
www.slkormicro.com
2
Instantaneous Reverse current (µA)
Instantaneous Forward current (A)
RS1A-RS1M
Instantaneous Forward Voltage (V)
Fig.3- Typical Instantaneous Forward
Characteristics
CJ Capacitance (pF)
Percentage of Peak Reverse Voltage (%)
Fig.4- Typical Reverse Characteristics
Reverse Voltage (V)
Fig.5- Junction Capacitance
Dimensions in inch (mm)
DO214AC
(SMA)
www.slkormicro.com
3
很抱歉,暂时无法提供与“RS1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05960
- 400+0.04703
- 800+0.04632
- 国内价格
- 1+0.06820
- 50+0.03421
- 2000+0.02585
- 国内价格
- 50+0.06502
- 500+0.05130
- 2000+0.04623
- 4000+0.03961
- 24000+0.03581
- 50000+0.03386
