DHE1A THRU DHE1M
SURFACE MOUNT HIGH EFFICIENCY RECTIFIER
Reverse Voltage - 50 to 1000 Volts
SOD-123FL
FEATURES
Cathode Band
Top View
1.8± 0.1
1.0±0.2
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.10-0.30
2.8±0.1
1.3± 0.15
Forward Current - 1.0 Ampere
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body over passivated chip
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time (NOTE 1)
DHE1A DHE1B DHE1D DHE1G DHE1J DHE1K DHE1M
U1A
VRRM
VRMS
VDC
50
35
50
U1B
100
70
100
U1D
U1G
U1J
U1K
U1M
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
25.0
Amps
VF
1.0
trr
1.7
5.0
100.0
IR
Typical thermal resistance
RθJA
Operating junction and storage temperature range TJ,TSTG
1.4
µA
75
50
180
-50 to +150
Volts
ns
K/W
C
Note: 1.Measured with IF=0.5A, IR=1A, Irr=0.25A.
2014-03 01版
http://www.microdiode.com
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES DHE1A THRU DHE1M
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
75
100
125
150
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
175
10
100
NUMBER OF CYCLES AT 60 Hz
AMBIENT TEMPERATURE, C
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
DHE1A-DHE1D
DHE1G
DHE1J-DHE1M
0.01
0.2
0.6
1.0
1.4
1.8
2.0
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1,000
100
TJ=100 C
10
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
2014-03 01版
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
很抱歉,暂时无法提供与“DHE1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08446
- 500+0.06696
- 3000+0.05422
- 6000+0.04839
- 24000+0.04331
- 51000+0.04050
- 国内价格
- 50+0.06688
- 600+0.05244
- 1200+0.05165
- 3000+0.04195
- 国内价格
- 1+0.21357
- 200+0.07108
- 1500+0.04441
- 3000+0.03526
- 国内价格
- 50+0.07445
- 600+0.05841
- 1200+0.05753
- 3000+0.04673
