SR220 THRU SR2200
Reverse Voltage - 20 to 200 Volts
Forward Current - 2.0 Ampere
SCHOTTKY BARRIER RECTIFIER
Features
DO-15
The plastic package carries Underwriters
Laboratory Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length, 5
lbs. (2.3kg) tension
1.0 (25.4)
MIN.
0.140 (3.6)
0.104(2.6)
DIA.
0.300(7.6)
0.230(5.8)
Mechanical Data
Case : JEDEC DO-15 Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Color band denotes cathode end
Mounting Position : Any
Weight : 0.014 ounce, 0.40 grams
1.0 (25.4)
MIN.
0.034 (0.86)
0.028 (0.70)
DIA.
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
SR SR SR SR SR SR SR SR SR SR SR
220 230 240 250 260 270 280 290 2100 2150 2200
SYMBOLS
MDD MDD MDD MDD MDD MDD MDD MDD MDD MDD MDD
VRRM
V RMS
V DC
Typical junction capacitance (NOTE 1)
CJ
Storage temperature range
40
28
40
50
35
50
60
42
60
70
49
70
IFSM
VF
Operating junction and storage
30
21
30
I(AV)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
Typical thermal resistance (NOTE 2)
56
80
100 150 200
70 105 140
100 150 200
A
60
A
0.85
0.5
IR
10.0
TJ
T STG
5.0
220
R θ JA
V
V
V
2.0
0.70
0.55
90
63
90
UNITS
80
50.0
-65 to +125
-65 to +150
-65 to +150
0.95
0.2
2.0
V
mA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
SR220 THRU SR2200
FIG. 1- FORWARD CURRENT DERATING CURVE
2.0
1.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.8
SR220-SR260
SR270-SR2200
0.4
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
60
48
36
24
12
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
SR220-SR240
SR250-SR260
SR270-SR2150
SR2200
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.001
60
80
100
2000
SR220-SR240
SR250-SR2200
100
TJ=25 C
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
1000
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
很抱歉,暂时无法提供与“SR2100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 200+0.19266
- 1000+0.18396
- 国内价格
- 10+0.50548
- 100+0.41894
- 300+0.37567
- 2500+0.27343
- 5000+0.24744
- 10000+0.23446
- 国内价格
- 5+0.22648
- 50+0.18041
- 150+0.15734
- 500+0.14010
- 2500+0.12623
- 5000+0.11937
