SB10100L
Reverse Voltage - 100Volts
Forward Current -10.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
TO-277
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Built-in strain relief,ideal for automated placement
Low forward voltage drop
High forward surge current capability
High temperature soldering guaranteed
250℃/10 seconds at terminals
Mechanical Data
Case : JEDEC TO-277 Molded plastic body
Terminals :Solder plated, solderable per MIL-STD-750,Method
2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.003 ounce, 0.092 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 ℃ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SB10100L
Parameter
SYMBOL
Marking Code
Maximum repetitive peak reverse voltage
VRRM
Maximum DC blocking voltage
VDC
RMS Reverse voltage
UNIT
MDD
SB10100L
100
V
VRMS
70
V
Average Rectified Output Current
I(O)
10
A
Non-Repetitive Peak Forward Surge8.3ms
Single Half Sine-Wave Superimposed on
rated load(JEDEC Method)
IFSM
150
A
Electrical Characteristics Ta=25℃ unless otherwise noted
Parameter
Forward Voltage Drop
Peak reverse curent at rated
DC blocking voltage
TestConditions
at 10A
TA=25℃
TA=125℃
Symbol
VF
IR
Value
Unit
Typ
Max
0.85
V
0.3
mA
15
mA
Typical thermal resistance
RθJA
80
℃/W
Operating junction temperature range
TJ
-55 to +150
TSTG
-55 to +150
Storage temperature range
Note:1.The typical data above is for referenceonly.
http://www.microdiode.com
Rev:2024A1
Page :1
SB10100L
Ratings And Characteristic Curves
Fig. 2 Typ. Forward Characteristics
12
Based on Lead Temp(T L )
8
4
50
7 5
100
125
150
17 5
Instantaneous Forward Current (A)
Average Forward Current (A)
Fig. 1 Forward Current Derating Curve
100
10
1.0
0.1
250
200
150
100
50
0.4
0.6
0.8
1.0
Fig.4 Typical Reverse Chracteristics
Instantaneous Reverse Current (uA)
I FSM, Peak Forward Surge Current (A)
300
10
VF, Instantaneous Forward Voltage (V)
Fig. 3 Max Non-Repetitive Peak Fwd Surge Current
2
SB10100L
TA =25
TL Lead Temperature( °C )
1
100
Number Of Cycles At 60 Hz
100
10
TA =100
1.0
0.1
TA =25
0.01
60
80
100
Percent Of Rated Peak Reverse Voltage (%)
Fig.5 Typical Junction Capacitance
Capacitance,(pF)
10000
1000
100
SB10100L
10
1.0
2
3
4
5
VR,Reverse Voltage (V)
The curve above is for reference only.
Rev:2024A1
Page :2
SB10100L
Packing information
P0
P1
unit:mm
d
E
Item
Symbol
Tolerance
TO-277
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
4.45
7.0
1.60
1.55
330.00
50.0
13.00
1.75
7.50
8.00
4.00
2.00
F
B
A
W
P
D2
D1
T
C
W1
D
0.25
12.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
TO-277
13"
5,000
4.0
10,000
210*208*203
330
430*430*235
80,000
13.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.142
B
3.60
5.35
C
1.50
0.059
D
1.85
0.073
E
4.30
0.169
Rev:2024A1
0.211
Page :3
很抱歉,暂时无法提供与“SB10100L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.78135
- 500+0.76942
- 国内价格
- 5+1.34973
- 50+1.08165
- 150+0.95091
- 500+0.83410
- 2500+0.66492
- 5000+0.64564
- 国内价格
- 5+1.34330
- 50+1.07250
- 150+0.94260
- 500+0.82610
- 2500+0.65830
- 5000+0.63920
- 国内价格
- 1+1.07100
- 100+0.82425
- 1250+0.68670
- 2500+0.62580
- 5000+0.57855
