1N4148W
SURFACE MOUNT FAST SWITCHING DIODE
Features
High Conductance
Fast Switching Speed
Surface Mount Package Ideally Suited for
Automatic Insertion
! For General Purpose Switching Application
C
! Plastic Material – UL Recognition Flammability
Classification 94V-O
A
SOD-123
D
B
E
Mechanical Data
H
Case: SOD-123, Molded Plastic
Terminals: Plated Leads Solderable per
MIL-STD-202, Method 208
Polarity: Cathode Band
Maximum Ratings
G
J
Dim
Min
A
3.6
Max
3.9
B
2.5
2.8
C
1.4
1.8
D
0.5
0.7
E
0.2
G
0.4
H
0.95
1.35
J
0.12
All Dimensions in mm
@TA=25°C unless otherwise specified
Characteristic
Symbol
Value
Unit
VRM
100
V
VRRM
VRWM
VR
75
V
VR(RMS)
53
V
Forward Continuous Current (Note 1)
IFM
300
mA
Average Rectified Output Current (Note 1)
IO
150
mA
IFSM
2.0
1.0
A
Pd
410
mW
RJA
315
K/W
Tj, TSTG
-65 to +150
°C
Symbol
Value
Unit
Non-Repetitive Peak Reverse Voltage
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Non-Repetitive Peak Forward Surge Current
@ t = 1.0µs
@ t = 1.0s
Power Dissipation (Note 1)
Typical Thermal Resistance, Junction to Ambient Air (Note 1)
Operating and Storage Temperature Range
Electrical Characteristics
Characteristic
Forward Voltage Drop
@ IF = 10mA
VFM
1.0
V
Peak Reverse Leakage Current
@ VR = 20V
@ VR = 75V
IRM
25
5.0
nA
µA
Typical Junction Capacitance (VR = 0V DC, f = 1.0MHz)
Cj
2.0
pF
Reverse Recovery Time (Note 2)
trr
4.0
nS
Note: 1. Valid provided that terminals are kept at ambient temperature.
2. Measured with IF = IR = 10mA, IRR = 0.1 x IR, RL = 100.
www.slkormicro.com
1
1000
10,000
100
IR, LEAKAGE CURRENT (nA)
IF, INSTANTANEOUS FORWARD CURRENT (mA)
1N4148W
10
1.0
0.1
1000
100
10
VR = 20V
1
0.01
2
100
200
Tj, JUNCTION TEMPERATURE (°C)
Fig. 2 Leakage Current vs Junction Temperature
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 1 Forward Characteristics
www.slkormicro.com
很抱歉,暂时无法提供与“1N4148W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.04960
- 1000+0.03860
- 3000+0.02730
- 9000+0.02360
- 51000+0.02050
- 99000+0.01870
- 国内价格
- 50+0.04571
- 600+0.03565
- 1200+0.03512
- 3000+0.02521
- 15000+0.02182
- 30000+0.02149
- 国内价格 香港价格
- 3000+0.093493000+0.01216
- 9000+0.075859000+0.00986
- 国内价格
- 1+0.13640
- 200+0.04554
- 1500+0.02849
- 3000+0.02255
- 国内价格 香港价格
- 1+0.885781+0.11515
- 10+0.3084210+0.04010
- 50+0.2187850+0.02844
- 100+0.18890100+0.02456
- 500+0.13432500+0.01746
- 国内价格
- 100+0.04987
- 1000+0.03889
- 3000+0.02750
- 9000+0.02381
- 51000+0.02063
- 99000+0.01888
