TPUSBLC6-2SC6
Low Capacitance 2-Line ESD Protection
www.sot23.com.tw
Features
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
–IEC61000-4-5 (Lightning) 6A (8/20μs)
RoHS Compliant
ϥ
Package: SOT23-6
ϥ ʳʳ Lead Finish: Matte Tin
ϥ
UL Flammability Classification Rating 94V-0
ϥ
Pb-Free, Halogen Free, RoHS/WEEE Compliant
Applications
ϥ USB 2.0 interface
IC
Mechanical Characteristics
ϥ 10/100 Ethernet
ϥ Personal digital assistants (PDA's)
ϥ Portable instrumentation
ϥ Digital cameras
Ordering Information
Reel Size
3000
7”
TE
CH
TPUSBLC6-2SC6
Qty per Reel
PU
Part Number
BL
ϥ Notebooks, Desktops and Servers
Dimensions and Pin Configuration
A
I/O1
VBUS
I/O2
I/O1
GND
I/O2
1
TPUSBLC6-2SC6
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
150
W
Peak Pulse Current (8/20µs)
Ipp
6
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±30
Symbol
Reverse stand-off voltage
TE
Clamping voltage (tp=8/20ȝs)
Typ
6
Max
Unit
5
V
9
V
VBR
IBR=1mA
IR
VR=5V
0.1
ȝA
VC
IPP=1A
10
V
VC
IPP=6A
15
V
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
0.8
1
pF
CJ
0Vdc,f=1MHz
I/O to I/O
0.35
0.4
pF
CH
Min
VRWM
Reverse breakdown voltage
Reverse leakage current
Test Condition
PU
Rating
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Junction capacitance
2
TPUSBLC6-2SC6
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPUSBLC6-2SC6
www.sot23.com.tw
Outline Drawing - SOT23-6
A
e1
D
DIM
N
H
EI
1
E
0.25
L
e
DETAIL
A
BL
D
aaa C
A2
A
SEE DETAIL
A1
C A-B D
CH
bxN
bbb
A
SIDE VIEW
PU
C
01
(L1)
B
SEATING
PLANE
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
N
01
aaa
bbb
ccc
c
GAGE
PLANE
2
ccc C
2X N/2 TIPS
H
IC
2X E/2
TE
Land Pattern - SOT23-6
X
DIM
(C)
G
C
G
P
X
Y
Z
Z
Y
P
4
DIMENSIONS
INCHES
MILLIMETERS
(.098)
.055
.037
.024
.043
.141
(2.50)
1.40
0.95
0.60
1.10
3.60
DIMENSIONS
MILLIMETERS
INCHES
MIN NOM MAX MIN NOM MAX
.057
.035
.000
.006
.035 .045 .051
.010
.020
.003
.009
.110 .114 .118
.060 .063 .069
.110 BSC
.037 BSC
.075 BSC
.012 .018 .024
(.024)
6
0°
10°
.004
.008
.008
1.45
0.90
0.15
0.00
.90 1.15 1.30
0.25
0.50
0.22
0.08
2.80 2.90 3.00
1.50 1.60 1.75
2.80 BSC
0.95 BSC
1.90 BSC
0.30 0.45 0.60
(0.60)
6
0°
10°
0.10
0.20
0.20
很抱歉,暂时无法提供与“TPUSBLC6-2SC6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33545
- 100+0.26147
- 300+0.22443
- 3000+0.19667
- 6000+0.17453
- 9000+0.16341
- 国内价格
- 1+0.34620
- 30+0.33401
- 100+0.30963
- 500+0.28525
- 1000+0.27306
