TPSRV05LC
Low Capactiance 4-Line TVS Array
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Ultra low capacitance: 0.3pF typical (I/O to I/O)
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 4 data lines and one power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±25kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) : 3A(8/20μs)
ROHS Compliant
USB 2.0 and USB 3.0 Ports
USB OTG
Digital video interface(DVI)
Monitor and Flat Panel Displays
PCI Express and Serial SATA Ports
Gigabit Ethernet
IEEE 1394 firewire ports
Consumer products (STB, DVD, DSC, DVC…)
BL
3000
Reel Size
7”
CH
PU
TPSRV05LC
Qty per Reel
IC
Applications
Ordering Information
Part Number
Package: SOT23-6
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
TE
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
WWW.TECHPUBLIC.COM.TW
TPSRV05LC
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(tp=8/20μs)
PPP
60
W
Peak Pulse Current(tp=8/20μs)
IPP
3
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
Operating Temperature Range
Storage Temperature Range
kV
±25
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
ESD per IEC 61000−4−2 (Contact)
Electrical Characteristics (TA=25°C unless otherwise specified)
Reverse Working Voltage
VBR
IR
Clamping Voltage
VC
6
CH
Reverse Leakage Current
Typ
VC
CJ
TE
Junction Capacitance
Max
5
VRWM
Breakdown Voltage
Clamping Voltage
Min
CJ
Unit
BL
Symbol
PU
Parameter
0.3
Test Condition
V
Any I/O pin to ground
V
IT = 1mA, any I/O pin to ground
0.5
µA
VRWM = 5V, any I/O pin to ground
15
V
IPP = 1A (8 x 20µs pulse) any I/O pin
to ground
V
IPP = 3A (8 x 20µs pulse) any I/O pin
to ground
0.4
pF
VR = 0V, f = 1MHz, between I/O pins
0.8
pF
VR = 0V, f = 1MHz, any I/O pin to
ground
Note 1: I/O pins are Pin 1, 3, 4 and 6
2
TPSRV05LC
PROTECTION PRODUCTS
WWW.SOT23.COM.TW
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
3
TPSRV05LC
TE
CH
PU
BL
IC
WWW.SOT23.COM.TW
4
很抱歉,暂时无法提供与“TPSRV05LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.29117
- 200+0.23350
- 600+0.20142
- 3000+0.16470
- 9000+0.14807
- 21000+0.13900
- 国内价格
- 20+0.26690
- 300+0.21404
- 1200+0.18463
- 3000+0.15097
