TPSRV05-4-P-T7
Low Capactiance 4-Line TVS Array
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Ultra low capacitance: 0.35 pF typical (I/O to I/O)
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 4 data lines and one power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±25kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
ROHS Compliant
3000
USB 2.0 and USB 3.0 Ports
USB OTG
Digital video interface(DVI)
Monitor and Flat Panel Displays
PCI Express and Serial SATA Ports
Gigabit Ethernet
IEEE 1394 firewire ports
Consumer products (STB, DVD, DSC, DVC…)
BL
Reel Size
7”
CH
PU
TPSRV05-4-P-T7
Qty per Reel
IC
Applications
Ordering Information
Part Number
Package: SOT23-6
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
TE
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
TPSRV05-4-P-T7
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Value
Symbol
ESD per IEC 61000−4−2 (Air)
±25
VESD
Operating Temperature Range
Storage Temperature Range
±25
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
ESD per IEC 61000−4−2 (Contact)
Unit
Electrical Characteristics (TA=25°C unless otherwise specified)
Reverse Working Voltage
VBR
IR
Clamping Voltage
VC
CJ
CJ
TE
Junction Capacitance
6
CH
Reverse Leakage Current
Typ
Max
5
VRWM
Breakdown Voltage
Min
Note 1: I/O pins are Pin 1, 3, 4 and 6
2
Unit
BL
Symbol
PU
Parameter
0.35
Test Condition
V
Any I/O pin to ground
V
IT = 1mA, any I/O pin to ground
0.3
µA
VRWM = 5V, any I/O pin to ground
V
IPP = 3A (8 x 20µs pulse) any I/O pin
to ground
0.4
pF
VR = 0V, f = 1MHz, between I/O pins
0.8
pF
VR = 0V, f = 1MHz, any I/O pin to
ground
TPSRV05-4-P-T7
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPSRV05-4-P-T7
TE
CH
PU
BL
IC
WWW.SOT23.COM.TW
4
很抱歉,暂时无法提供与“TPSRV05-4-P-T7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46094
- 100+0.36590
- 600+0.31838
- 1200+0.31360
- 3000+0.26463
- 国内价格
- 10+0.43092
- 100+0.33972
- 300+0.29412
- 国内价格
- 10+0.50285
- 100+0.39917
- 300+0.34733
- 3000+0.28869
- 6000+0.25758
- 9000+0.24192
