TPSPE0521D52RGB
Mechanical Characteristics
• Ultra low capacitance: 5pF typical
Package: SOD-523(0603)
• Ultra low leakage: nA level
Lead Finish: NiPdAu
• Low operating voltage: 5V
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
• Low clamping voltage
• 2-pin leadless package
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±20kV
• – IEC61000-4-5 (Lightning) 4A (8/20μs)
Qty per Reel
Reel Size
TPSPE0521D52RGB
3000
7”
Display Ports
• MDDI Ports
• USB Ports
• Digital Video Interface (DVI)
TE
CH
PU
Part Number
Smart phones
BL
Ordering Information
IC
• Complies with following standards:
Dimensions and Pin Configuration
1
WWW.TECHPUBLIC.COM.TW
TPSPE0521D52RGB
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
80
W
Peak Pulse Current (8/20µs)
IPP
4
A
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Clamping Voltage
VRWM
Junction Capacitance
Tstg
−55 to +150
°C
Test Condition
Min
Typ
Max Unit
5.0
V
8.5
V
VRWM = 5.0V
500
nA
VC
IPP = 1A (8 x 20µs pulse)
10
V
VC
IPP = 4A (8 x 20µs pulse)
13
V
CJ
VR = 0V, f = 1MHz
10
pF
VBR
IR
TE
Clamping Voltage
°C
PU
Reverse Leakage Current
−55 to +125
IT = 1mA
6.0
7.5
CH
Breakdown Voltage
TJ
BL
Symbol
Reverse Working Voltage
kV
±20
IC
Storage Temperature Range
Parameter
±20
VESD
5
2
TE
CH
PU
BL
IC
TPSPE0521D52RGB
3
TPSPE0521D52RGB
TE
CH
PU
(0603)
BL
IC
(0603)
4
很抱歉,暂时无法提供与“TPSPE0521D52RGB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.21374
- 300+0.16949
- 1200+0.14494
- 3000+0.13019
- 国内价格
- 20+0.23372
- 200+0.18533
- 600+0.15844
- 3000+0.14235
- 9000+0.12842
- 21000+0.12086
