关注公众号新品资讯
TPSP3010-04UTG
4-Line Uni-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
u
Low capacitance: 0.35 pF typical (I/O to I/O)
u
Low operating voltage: 5V
u
RoHS Compliant
u
IEC61000-4-2 (ESD) ±25kV (air), ±20kV (contact)
u
IEC61000-4-4 (EFT) 40A (5/50ηs)
u
IEC61000-4-5 (Lightning) 4.3A(8/20μs)
u
Package: DFN2510-10 (2.5×1.0×0.5mm)
u
Ultra low leakage: nA level
u
Case Material: “Green” Molding Compound.
u
UL Flammability Classification Rating 94V-0
u
Moisture Sensitivity: Level 3 per J-STD-020
u
Terminal Connections: See Diagram Below
Applications
7”
u
MDDI Ports
u
PCI Express
u
Serial ATA
C
Unified Display Interface (UDI)
UB
3000
Reel Size
u
CH
P
TPSP3010-04UTG
Qty per Reel
Digital Visual Interface (DVI)
Dimensions and Pin Configuration
TE
Part Number
High Definition Multimedia Interface (HDMI)
u
LI
Ordering Information
u
WWW.TECHPUBLIC.COM.TW
关注公众号新品资讯
TPSP3010-04UTG
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
I pp
4.3
A
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
±25
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±20
Symbol
Reverse Working Voltage
VBR
Reverse Leakage Current
Clamping Voltage
IR
Typ
6.8
CH
Breakdown Voltage
VRWM
Min
VC
CJ
0.35
CJ
0.6
TE
Junction Capacitance
Max
Unit
5
V
Any I/O pin to ground
9.5
V
IT = 1mA, any I/O pin to ground
0.08
µA
VRWM = 5V, any I/O pin to ground
15
V
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
pF
0.8
pF
Test Condition
IPP = 4.3A (8 x 20µs pulse), any I/O
pin to ground
VR = 0V, f = 1MHz, between I/O
pins
VR = 0V, f = 1MHz, any I/O pin to
ground
关注公众号新品资讯
TPSP3010-04UTG
www.sot23.com.tw
Characteristic Curves
8/20μs Pulse Waveform
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
tr
100
Peak Value IPP
80
100%
TEST
WAVEFORM
PARAMETERS
tr=8μs
td=20μs
Percent of Peak Pulse Current %
60
40
td=t IPP/2
10
15
30
t - Time (μs)
tr = 0.7~1ns
Time (ns)
30ns
60ns
Non - Repetitive Peak Pulse Power vs. Pulse Time
CH
10
1
0.1
TE
Peak Pulse Power - PPK (kW)
10%
PU
Fig3.
90%
BL
IPP - Peak Pulse Current - % of IPP
120
IC
Fig1.
0.01
0.1
1
10
100
1000
Pulse Duration - tp (μs)
关注公众号新品资讯
TPSP3010-04UTG
www.sot23.com.tw
Application Information
1
2
3
GND
8
4
1
2
3
GND
8
4
IC
BL
5
IC
5
1
2
3
8
PU
GND
4
5
TE
CH
ESD protection for HDMI port
TMDS_D2+
TMDS_D2_
TMDS_GND
TMDS_D1+
TMDS_D1_
TMDS_D0+
TMDS_D0_
TMDS_GND
TMDS_CK+
TMDS_CK_
CE_REMOTE
DDC_CLK
DDC_DAT
HOTPLUG_DET
关注公众号新品资讯
TPSP3010-04UTG
www.sot23.com.tw
Outline Drawing - DFN2510-10
D
B
DIM
E
A
SEATING
PLANE
aaa C
A2
b1xN
bbb
R0.125
1
2
C A B
PU
E/2
C
A1
A
A1
A2
b
b1
D
E
e
L
N
aaa
bbb
BL
PIN 1
INDICATOR
(LASER MARK)
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.020 .023 .026 0.50 0.58 0.65
0.00 .001 .002 0.00 0.03 0.05
(.005)
(0.13)
.006 .008 .010 0.15 0.20 0.25
.014 .016 .018 0.35 0.40 0.45
.094 .098 .102 2.40 2.50 2.60
.035 .039 .043 0.90 1.00 1.10
.020 BSC
0.50 BSC
.012 .015 .017 0.30 0.38 0.425
8
8
0.08
.003
0.10
.004
IC
A
LxN
2X R0.075
7 PLACES
CH
N
bxN
e
bbb
C A B
TE
D/2
Land Pattern - DFN2510-10
P1
P
DIMENSIONS
Y
Z (C)
(Y1)
G
X
X1
DIM
C
G
P
P1
X
X1
Y
Y1
Z
INCHES
(.034)
.008
.020
.039
.008
.016
.027
(.061)
.061
MILLIMETERS
(0.875)
0.20
0.50
1.00
0.20
0.40
0.675
(1.55)
1.55
很抱歉,暂时无法提供与“TPSP3010-04UTG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48817
- 100+0.40461
- 600+0.36274
- 1200+0.35730
- 3000+0.26938
- 国内价格
- 10+0.53255
- 100+0.44140
- 300+0.39572
- 3000+0.29387
- 6000+0.26655
- 9000+0.25283
