TPSMS05T1G
4-Line TVS Array
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
ROHS Compliant
Package: SOT23-6
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Part Number
3000
Reel Size
7”
CH
PU
TPSMS05T1G
Qty per Reel
Cell phone Handsets and Accessories
Microprocessor Based Equipment
Personal Digital Assistants (PDA’s) and Pagers
Desktops PC and Servers
Notebook, Laptop, and Palmtop Computers
Portable Instrumentation
Peripherals
BL
Ordering Information
IC
Applications
TE
Dimensions and Pin Configuration
W
1
TPSMS05T1G
4-Line TVS Array
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
150
W
Peak Pulse Power (8/20μs)
(Vcc-GND)
ESD per IEC61000-4-2 (Air)
±30
VESD
ESD per IEC61000-4-2 (Contact)
kV
±30
TJ
-55 to +125
Storage Temperature Range
Tstg
-55 to +150
IC
Operating Temperature Range
Electrical Characteristics (TA=25°C unless otherwise specified)
Typ
Max
VRWM
Unit
Test Condition
5
V
6
8.5
V
IT=1mA
Breakdown Voltage
VBR
Leakage Current
ILeak
100
nA
VRWM=5V
Clamping Voltage
VC
11
V
IPP=4.5A,Tp=8/20μs
Clamping Voltage
CH
Reverse Working Voltage
Min
BL
Symbol
PU
Parameter
14
V
IPP=10A,Tp=8/20μs
90
pF
VR=0V, f=1MHz,
pF
VR=0V, f=1MHz,
VC
Junction Capacitance
(I/O to I/O )
CJ
TE
(I/O to GND)
60
30
CJ
2
TPSMS05T1G
4-Line TVS Array
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPSMS05T1G
4-Line TVS Array
TE
CH
PU
BL
IC
WWW.SOT23.COM.TW
4
很抱歉,暂时无法提供与“TPSMS05T1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.46462
- 50+0.41562
- 600+0.37269
- 1200+0.36710
- 3000+0.32585
- 国内价格
- 5+0.51203
- 50+0.45803
- 150+0.43103
- 500+0.41073
- 3000+0.35910
- 6000+0.35100
