TPSMF05CT1G
TPSMF05CT1G
    TECHPUBLIC(台舟)
    SOT363
    ESD抑制器/TVS二极管 VRWM=5V VBR(min)=6V VC=10V@IPP=1A SOT363
TPSMF05CT1G 数据手册
TPSMF05CT1G 5-Line TVS Array www.sot23.com.tw Mechanical Characteristics Features • Working voltage: 5V • • Low clamping voltage • Lead Finish: Matte Tin • Protects five I/O lines • Case Material: “Green” Molding Compound. • Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) • UL Flammability Classification Rating 94V-0 • Moisture Sensitivity: Level 3 per J-STD-020 • • • Ordering Information Reel Size 3000 7” Microprocessor Based Equipmenmt Cell Phone Handsets and Accessories Personal Digital Assistants (PDAs) and Pagers PU TPSMF05CT1G Qty per Reel CH Part Number Portable Instrumentation BL • IC Applications RoHS Compliant Dimensions and Pin Configuration TE • Package: SOT-363 (2.0X2.1X0.35mm) Pin Configuration TPSMF05CT1G 5-Line TVS Array www.sot23.com.tw Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Ppk 100 W Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range −55 to +125 °C Tstg −55 to +150 °C Reverse Working Voltage Breakdown Voltage Min VRWM VBR 6 Typ Max Unit 5 V PU Symbol BL Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Test Condition V IT = 1mA 0.1 uA VRWM = 5V IR Forward Voltage VF 1.2 V IF = 15mA Clamping Voltage VC 10 V IPP 1A=(8 x 20us pulse) pF VR = 0V, f = 1MHz TE CH Reverse Leakage Current Junction Capacitance CJ Note 1: I/O pins are Pin 1, 3, 4, 5 and 6 30 kV TJ IC Storage Temperature Range ±8 TPSMF05CT1G 5-Line TVS Array www.sot23.com.tw PROTECTION PRODUCTS Typical charateristics Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 60 40 td=t IPP/2 0 0 5 10 15 20 25 30 CH Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 TE % of Rated Power PU t - Time ( s) Fig3. 0 25 50 75 100 125 Ambient Temperature –TA (ºC) 10% BL 20 90% IC tr Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 150 tr = 0.7~1ns 30ns 60ns Time (ns) TPSMF05CT1G 5-Line TVS Array www.sot23.com.tw Outline Drawing - SOT-363(2.0X2.1) DIM D e1 A A1 A2 b c D E1 E e e1 L L1 N 01 aaa bbb ccc N E/2 E1 1 ccc C 2X N/2 TIPS E 2 e B D A2 A SEATING PLANE bxN bbb 1.10 0.00 0.10 0.70 0.90 1.00 0.15 0.30 0.08 0.22 1.80 2.00 2.20 1.15 1.25 1.35 2.10 BSC 0.65 BSC 1.30 BSC 0.26 0.36 0.46 (0.42) 6 0° 8° 0.10 0.10 0.30 H A1 C .043 .000 .004 .028 .035 .039 .012 .006 .003 .009 .071 .079 .087 .045 .049 .053 .083 BSC .026 BSC .051 .010 .014 .018 (.017) 6 8° 0° .004 .004 .012 BL aaa C DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX IC A C A-B D GAGE PLANE PU 0.15 SEE DETAIL 01 (L1) DETAIL A A CH SIDE VIEW L c TE Land Pattern - SOT-363 X DIM C G Y P Z C G P X Y Z DIMENSIONS INCHES MILLIMETERS (.073) .039 .026 .016 .033 .106 (1.85) 1.00 0.65 0.40 0.85 2.70
TPSMF05CT1G
物料型号:TPSMF05CT1G
器件简介:这是一个5线TVS阵列,用于保护五个I/O线路,工作电压为5V,具有低钳位电压,符合IEC 61000-4-2(ESD)和IEC61000-4-4(EFT)标准。
引脚分配:文档中提供了引脚配置图,但未明确列出每个引脚的功能。通常,I/O引脚是1、3、4、5和6。
参数特性: - 工作电压:5V - 钳位电压:未明确给出具体值,但提到了低钳位电压 - ESD保护:符合IEC 61000-4-2标准,空气放电±15kV,接触放电±8kV - EFT保护:符合IEC61000-4-4标准,40A(5/50ns)
功能详解: - 该器件用于保护电子设备免受静电放电和电快速瞬变的影响。
应用信息: - 便携式仪器 - 基于微处理器的设备 - 手机及其配件 - 个人数字助理(PDA)和寻呼机
封装信息: - 封装类型:SOT-363 (2.0X2.1X0.35mm) - 引脚镀层:亚光锡 - 封装材料:"绿色"模具化合物 - UL阻燃等级:94V-0 - 湿度敏感性:根据J-STD-020标准,等级3
电气特性: - 反向工作电压:5V - 击穿电压:最小6V - 反向漏电流:最大0.1uA(在5V反向工作电压下) - 正向电压:在15mA正向电流下,最大1.2V - 钳位电压:在1A(8x20us脉冲)下,最大10V - 结电容:在0V反向电压和1MHz频率下,最小30pF
