TPSM24CANA-02HTG
CAN bus ESD protection diode
www.sot23.com.tw
Mechanical Characteristics
Features
Lead Finish: Matte Tin
UL Flammability Classification Rating 94V-0
Shipping Qty : 3000pcs/7InchTape & Reel
Applications
IC
Cell Phones
Audio Interface Connections
Consumer Electronics (DVR, Set-Top Box, TV)
CAN bus protection
Automotive applications
BL
Package: SOT23
PU
CH
Ultra low leakage: nA level
Operating voltage: 24V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
–IEC61000-4-5 (Lightning) 3A (8/20μs)
RoHS Compliant
Dimensions and Pin Configuration
TE
1
3
2
TPSM24CANA-02HTG
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
150
W
Peak Pulse Current (8/20µs)
Ipp
3
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
±30
IC
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
BL
Storage Temperature Range
Symbol
Breakdown Voltage
Clamping Voltage
VBR
Junction Capacitance
Typ
VC
CJ
Max
Unit
24
V
10
Test Condition
V
IT = 1mA
0.08
uA
VRWM =24V
50
V
IPP = 3A (8 x 20 s pulse)
25
IR
TE
Reverse Leakage Current
VRWM
Min
CH
Reverse Working Voltage
PU
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
kV
pF
VR = 0V, f = 1MHz
TPSM24CANA-02HTG
www.sot23.com.tw
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
t - Time ( s)
Fig3.
Power Derating Curve
30
CH
90
80
70
60
50
40
30
TE
% of Rated Power
110
100
25
PU
50
75
10%
BL
90%
100
125
Ambient Temperature –TA (ºC)
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
150
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPSM24CANA-02HTG
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E
C
c
IC
E1
GAUGE
PLANE
SEATING
PLANE
L
L1
DETAIL A
2
bxN
C A B
A2
A
3X
aaa C
PU
bbb
e
BL
1
SEATING PLANE
A1
SIDE VIEW
TE
CH
C
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
E
E1
C
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
SEE DETAIL A
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.08
0.18
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“TPSM24CANA-02HTG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32731
- 100+0.25756
- 600+0.22269
- 1200+0.21935
- 3000+0.19655
- 国内价格
- 10+0.34472
- 100+0.27126
- 600+0.23453
- 1200+0.23101
- 3000+0.20701
- 国内价格
- 10+0.37606
- 100+0.29592
- 300+0.25586
- 3000+0.22583
- 6000+0.20186
- 9000+0.18976
