TPSM12T1G
TVS Diode Array
WWW.SOT23.COM.TW
Mechanical Characteristics
Features
Ordering Information
Part Number
3000
Reel Size
7”
Lead Finish: Matte Tin
UL Flammability Classification Rating 94V-0
Pb-Free, Halogen Free, RoHS/WEEE Compliant
Applications
USB Power & Data Line Protection
Monitors and Flat Panel Displays
I²C Bus Protection
Portable Instrumentation
Set Top Box
CH
PU
TPSM12T1G
Qty per Reel
Package: SOT23
IC
150 Watts peak pulse power (tp = 8/20μs)
Transient protection for high speed data lines to
IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Working voltages : 12V
Protects one bidirectional line or two unidirectional lines
Low operating and clamping voltages
Solid-state silicon avalanche technology
BL
TE
Dimensions and Pin Configuration
Circuit and Pin Schematic
A
TPSM12T1G
TVS Diode Array
WWW.SOT23.COM.TW
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
150
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±15
VESD
ESD per IEC 61000−4−2 (Contact)
kV
±8
Storage Temperature Range
TJ
−55 to +125
Tstg
−55 to +150
°C
IC
Operating Temperature Range
°C
TPSM12T1G
IDRM
I
VBR
V
IR
I
VC
IPP
I
VC
IPP
CO
V
uA
V
mA
V
A
V
A
pF
MAX
MIN
1
13.3
12
PU
Number
Part
Number
VVRWM
MAX
1
19
CH
Part
TE
specified
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
1
MAX
MAX
25
MAX
5.5
65
TPSM12T1G
TVS Diode Array
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
Ambient Temperature –TA (ºC)
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
150
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPSM12T1G
TVS Diode Array
WWW.SOT23.COM.TW
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
C
c
IC
E1
GAUGE
PLANE
SEATING
PLANE
E
L
L1
DETAIL A
1
2
A2
A
C A B
3X
aaa C
PU
bbb
BL
bxN
e
SEATING PLANE
A1
CH
TE
Land Pattern - SOT23
C
SIDE VIEW
X
Y
DIM
Z
G
Y
E
E1
C
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
SEE DETAIL A
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.51
0.30
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“TPSM12T1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20562
- 300+0.16454
- 1200+0.14167
- 3000+0.11741
- 国内价格
- 20+0.22432
- 200+0.17950
- 600+0.15455
- 3000+0.12809
- 9000+0.11513
- 21000+0.10811
- 国内价格
- 20+0.17605
- 300+0.13736
- 1200+0.11588
- 3000+0.09319
