TPRT90 13 Series
500 0 mA H igt PSRR Voltage Reaulators
www.sot23.com.tw
The TPRT9013 is available in 5pin SOT23-5 Package .t
The TPRT9013 is a high-performance, 500mA LDO regulator,
offering extremely high PSRR and ultra-low dropout. Ideal
for portable RF and wireless applications with demanding
performance and space requirements.
output standards of 1.2V 1.5V 1.8V 2.5V 2.8V 3.0V 3.3V
Quiescent Current: 60uA
CDM/GSM
mobile phone
PSRR:75dB@1KHz
PDAs /MP3
< 1uA current at shutdown mode
Audio/Video equipment
Output voltage accuracy: tolerance ±2%
Output current:500mA(Typ.)
SOT23 -5 package
BL
PU
Ordering Information
IC
GB:SOT23-5 Package
TE
CH
TPRT90 13-33GB
Output voltage: 33=3.3V
50=5.0V
28=2.8V
30=3.0V
XX=X.XV
1
TPRT90 13 Series
www.sot23.com.tw
CH
PU
BL
IC
BLOCK DIAGRAM
TE
PIN CONFIGURATION
VOUT
CE
SOT23-5
2
Pin Name
Function
VIN
Supply power
GND
Ground
CE
Enable pin
NC
NC
VOUT
Voltage output
TPRT90 13 Series
www.sot23.com.tw
Absolute Maximum Rating ( TA=25°C
Parameter
unless otherwise noted)
Symbol
Input Voltage
VIN
Output Voltage
VOUT
Output Current
Iout
Maximum Rating
7
mA
600
SOT-23-5
250
Operating Ambient Temperature
Topr
-40~+85
Storage Temperature
Tstg
-40~+125
Electrical Characteristics
V
VSS-0.3~VIN+0.3
PD
Power Dissipation
Unit
mW
°C
( T =25°C unless otherwise noted)
O
(Vin=Vout+1V,Cin=Cout=1uF,Ta=25 C)
CONDITIONS
Output Voltage
VOUT(E)
(Note 2)
IOUT=40mA,
VIN=Vout+1V
Input Voltage
VIN
Supply Current
Standby
Current
X 0.98
VOUT (T)
(Note 1)
MAX
UNITS
X 1.02
V
7.0
V
VIN=Vout+1V
500
mA
VCE
VIN=Vout+1V
1.1
V
50
mV
Vdif1
Vdif2
VIN=Vout+1V,
1mA≤IOUT≤100mA
IOUT =100mA
IOUT =200mA
100
300
mV
mV
ISS
VIN=Vout+1V
60
μA
ICEL
Vce=0V
1
μA
IOUT =40mA
Vout+1V ≤VIN≤8V
0.03
%/V
50
uVrms
70
dB
∆VOUT
∆VOUT
∆VIN • VOUT
Output Noise
en
TE
Line Regulation
Ripple
Rejection Rate
TYP
IOUTmax
CH
PU
Max. Output
Current
CE Enable
Voltage
Load
Regulation
Dropout Voltage
(Note 3)
MIN
IC
SYMBOL
BL
PARAMETER
PSRR
IOUT =40mA,
300Hz~50kHz
Vin= [Vout+1]V
+1Vp-pAC
IOUT =40mA,f=1kHz
3
TPRT90 13 Series
www.sot23.com.tw
TYPICAL APPLICATION
VIN
CIN
1uF
VOUT
VIN
VOUT
COUT
1uF
CE
TE
CH
PU
BL
IC
GND
4
TPRT90 13 Series
www.sot23.com.tw
Package informantion
TE
CH
PU
BL
IC
SOT23-5
5
很抱歉,暂时无法提供与“TPRT9013-30GB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41492
- 100+0.32562
- 600+0.28097
- 1200+0.27676
- 国内价格
- 5+0.60848
- 50+0.48428
- 150+0.42218
- 500+0.37552
- 3000+0.32994
- 6000+0.31137
