TPRCLAMP0542T
Low Capacitance TVS Diode Array
WWW.SOT23.COM.TW
Features
Ultra Low Capacitance 0.5pF typical
Low operating Voltage: 5.0 V
Low clamping voltage
Mechanical Characteristics
JEDEC DFN1610-6 package
Molding compound flammability rating: UL 94V-0
IEC61000−4−4 (EFT) 40A (5/50ns)
IEC61000-4-5(Lightning)5A(5/50ns)
Ordering Information
Reel Size
3000
7”
SATA and eSATA
DVI
BL
HDMI 1.3
IEEE 1394
PCI Express
Portable Electronics
Notebooks
PU
Dimensions and Pin Configuration
CH
TPRCLAMP0542T
Qty per Reel
USB 2.0
Internal Structure
TE
Part Number
IC
Applications
Pin 1
6
5
4
1
2
3
Pin 2
3, 4
1
Pin
Identification
1-2
Input Lines
5-6
Output Lines
(No Internal Connection)
3-4
Ground
WWW.TECHPUBLIC.COM.TW
TPRCLAMP0542T
PROTECTION PRODUCTS
WWW.SOT23.COM.TW
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
150
W
Peak Pulse Current (8/20µs)
IPP
5
A
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
TJ
Storage Temperature Range
Clamping Voltage
Junction Capacitance
−55 to +150
BL
Unit
°C
Test Condition
V
V
IT = 1mA
0.5
µA
VRWM = 5.0V
VC
15
V
VC
25
V
1.0
pF
CH
6.0
IR
TE
Clamping Voltage
Max
5.0
VRWM
VBR
Typ
PU
Min
DP, DM, USB ID TVS
Reverse Leakage Current
°C
Symbol
Breakdown Voltage
−55 to +125
Tstg
Electrical Characteristics
Reverse Working Voltage
kV
±20
IC
Operating Temperature Range
Parameter
±25
VESD
CJ
0.5
2
IPP = 1A (8 x 20µs pulse), any I/O
pin to ground
IPP = 5A (8 x 20µs pulse), any I/O
pin to ground
VR = 0V, f = 1MHz, any I/O pin to
ground
TPRCLAMP0542T
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
110
100
tr = 0.7~1ns
Time (ns)
30ns
60ns
CH
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
IC
80
90%
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
3
TPRCLAMP0542T
WWW.SOT23.COM.TW
Outline Drawing - DFN1610-6
D
DIMENSIONS
INCHES
MILLIMETERS
DIM
MIN NOM MAX MIN NOM MAX
B
E
A
SEATING
PLANE
aaa C
A2
bxN
C A B
b1xN
bbb
1
2
2X R0.075
3 PLACES
N
0.50 0.58 0.65
0.00 0.03 0.05
(0.13)
0.15 0.20 0.25
0.35 0.40 0.45
1.50 1.60 1.70
0.90 1.00 1.10
0.50 BSC
1.00 BSC
0.30 0.38 0.43
4
0.08
0.10
C A B
R0.125
CH
E/2 LxN
.020 .023 .026
0.00 .001 .002
(.005)
.006 .008 .010
.014 .016 .018
.059 .063 .067
.035 .039 .043
.020 BSC
.039 BSC
.012 .015 .017
4
.003
.004
PU
bbb
C
A1
A
A1
A2
b
b1
D
E
e
e1
L
N
aaa
bbb
BL
PIN 1
INDICATOR
(LASER MARK)
IC
A
e
e1
NOTES:
TE
D/2
4
很抱歉,暂时无法提供与“TPRCLAMP0542T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.46200
- 10+0.44450
- 100+0.40250
- 500+0.38150
- 国内价格
- 5+0.37684
- 50+0.24559
- 150+0.16663
- 500+0.14833
- 3000+0.13371
- 6000+0.12636
