TPRCLAMP0521P
1-Line Bi-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
⚫ Package: DFN1006-2 (0402)
⚫ Lead Finish: Matte Tin
⚫ Ultra small package: 1.0x0.6x0.5mm
⚫ Ultra low capacitance:0.3pF typical
⚫ Case Material: “Green” Molding Compound.
⚫ Moisture Sensitivity: Level 3 per J-STD-020
IC
⚫ Ultra low leakage: nA level
⚫ Low operating voltage: ±5V
⚫ Terminal Connections: See Diagram Below
⚫ Low clamping voltage
BL
⚫ 2-pin leadless package
Applications
⚫ Complies with following standards:
⚫ – IEC 61000-4-2 (ESD) immunity test
⚫ Cellular Handsets & Accessories
Air discharge: ±20kV
Contact discharge: ±15kV
- - (Lightning)4A (8/20 μs)
⚫ – IEC61000-4-5
⚫ RoHS Compliant
Part Number
TPRCLAMP0521P
PU
⚫ USB Ports
TE
Ordering Information
CH
⚫ Lead Finish: NiPdAu
⚫ Digital Visual Interface (DVI)
⚫ Display Port
⚫ MDDI Ports
Qty per Reel
Reel Size
3000 OR 3000
10000
7”
Dimensions and Pin Configuration
WWW.TECHPUBLIC.COM.TW
TPRCLAMP0521P
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
70
W
Peak Pulse Current (8/20µs)
Ipp
4
A
ESD per IEC 61000−4−2 (Air)
±20
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Operating Temperature Range
kV
±15
BL
Storage Temperature Range
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
Junction Capacitance
Unit
Test Condition
V
9.0
V
IR
0.08
uA
VC
9
V
Ipp=1A(8x 20us pulse)
15
V
Ipp=4A(8x 20us pulse)
pF
VR = 0V, f = 1MHz
6.5
TE
Clamping Voltage
Max
5
VBR
Reverse Leakage Current
Clamping Voltage
VRWM
Typ
7.5
CH
Breakdown Voltage
Min
PU
Parameter
VC
CJ
0.3
2
IT = 1mA
VRWM = 5V
TPRCLAMP0521P
www.sot23.com.tw
TE
CH
PU
BL
IC
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
3
TPRCLAMP0521P
www.sot23.com.tw
DFN1006-2 Package Outline Drawing (0402)
h
h
A
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
b
E
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
L
A1
c
A
Bottom View
0.65 BSC
BL
e
IC
e
D
0.026 BSC
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Y3
Y2
TE
Suggested Land Pattern
CH
PU
E
Y1
SYM
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
4
很抱歉,暂时无法提供与“TPRCLAMP0521P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.22432
- 200+0.17950
- 600+0.15455
- 2000+0.13954
- 10000+0.11513
- 20000+0.10811
- 国内价格
- 20+0.20562
- 1000+0.14167
- 4000+0.12791
- 10000+0.10553
