TPPESD5V0X1BL
TPPESD5V0X1BL
    TECHPUBLIC(台舟)
    ESD抑制器/TVS二极管 VRWM=5V VBR(Min)=6V VC=20V IPP=2A 0402
TPPESD5V0X1BL 数据手册
TPPESD5V0X1BL 1-Line Bi-directional TVS Diode www.sot23.com.tw Features Mechanical Characteristics  Ultra small package: 1.0x0.6x0.5mm  Ultra low capacitance: 0.8pF typical  Ultra low leakage: nA level  Low operating voltage: 5V  Low clamping voltage  2-pin leadless package ⚫ Case Material: “Green” Molding Compound. ⚫ Moisture Sensitivity: Level 3 per J-STD-020 ⚫ Terminal Connections: See Diagram Below Applications IC Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-5 (Lightning) 2A (8/20μs) ⚫ BL ⚫ ⚫ ⚫ RoHS Compliant  Lead Finish: NiPdAu PU ⚫  Cellular Handsets and Accessories Personal Digital Assistants Notebooks and Handhelds Portable Instrumentation Digital Cameras Peripherals Ordering Information Part Number Qty per Reel Reel Size TPPESD5V0X1BL 3000 10000 7” ⚫ TE CH  ⚫ Package: DFN1006-2 (0402) ⚫ Lead Finish: Matte Tin Dimensions and Pin Configuration TPPESD5V0X1BL 1-Line Bi-directional TVS Diode www.sot23.com.tw Absolute Maximum Ratings (Tamb=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 60 W Peak Pulse Current (8/20µs) Ipp 2 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) −55 to +125 °C Tstg −55 to +150 °C BL Storage Temperature Range Electrical Characteristics (TA=25°C unless otherwise specified) Symbol Reverse Working Voltage VBR Clamping Voltage Junction Capacitance Max 5 6 Unit Test Condition V V IT = 1mA IR 0.1 uA VC 12 V Ipp=1A(8x 20us pulse) VC 20 V Ipp=2A(8x 20us pulse) pF VR = 0V, f = 1MHz TE Reverse Leakage Current Clamping Voltage VRWM Typ CH Breakdown Voltage Min PU Parameter CJ 0.8 2 kV TJ IC Operating Temperature Range ±30 VRWM =5V TPPESD5V0X1BL 1-Line Bi-directional TVS Diode www.sot23.com.tw TE CH UB LI C Typical Performance Characteristics (TA=25°C unless otherwise Specified) 3 TPPESD5V0X1BL 1-Line Bi-directional TVS Diode www.sot23.com.tw DFN1006-2 Package Outline Drawing (0402) h h A A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM - b E - DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 L A1 c A Bottom View 0.65 BSC BL e IC e D 0.026 BSC 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 ╋ Y3 Y2 TE Suggested Land Pattern CH PU E Y1 SYM Z DIMENSIONS MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 ╋ X 4
TPPESD5V0X1BL 价格&库存
很抱歉,暂时无法提供与“TPPESD5V0X1BL”相匹配的价格&库存,您可以联系我们找货
TPPESD5V0X1BL
  • 20+0.21077
  • 1000+0.14216
  • 4000+0.12741
  • 10000+0.10167
库存:10000
