TPPESD5V0S1UB
1-Line Uni-directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
150 Watts peak pulse power (tp = 8/20μs)
Transient protection for high speed data lines to
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Protects One Power or I/O Port
Low leakage current
Low operating and clamping voltages
Solid-state silicon avalanche technology
Package: SOD-523
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
3000
Reel Size
7”
Portable Instrumentation
Digital Cameras
Peripherals
Audio Players
Keypads, Side Keys, LCD Displays,USB2.0
PU
Qty per Reel
Notebooks and Handhelds
CH
TPPESD5V0S1UB
Personal Digital Assistants
TE
Part Number
Cellular Handsets and Accessories
BL
Ordering Information
IC
Applications
Dimensions and Pin Configuration
1
TPPESD5V0S1UB
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
ESD per IEC 61000−4−2 (Air)
Value
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
Unit
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VBR
Maximum Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IF
Forward Current
VF
Forward Voltage @ IF
Ppk
Peak Power Dissipation
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol
Min
IF
IR VF
IT
Uni−Directional TVS
Typ
VRWM
VBR
I
IPP
Capacitance @ VR = 0 and f = 1.0 MHz
TE
C
VC VBR VRWM
PU
IR
Working Peak Reverse Voltage
CH
VRWM
BL
Symbol
IC
Electrical Characteristics (TA=25°C unless otherwise specified)
Max
Unit
5
V
6
Test Condition
V
IT = 1mA
IR
0.2
uA
VRWM =5V
Clamping Voltage
VC
12
V
IPP = 5A (8 x 20 s pulse)
Clamping Voltage
VC
15
V
IPP = 10A (8 x 20 s pulse)
Junction Capacitance
CJ
pF
VR = 0V, f = 1MHz
30
2
V
TPPESD5V0S1UB
www.sot23.com.tw
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
80
60
40
td=t IPP/2
10
15
t - Time ( s)
Power Derating Curve
PU
Fig3.
CH
TE
% of Rated Power
110
100
90
80
70
60
50
40
30
90%
10%
IC
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
BL
IPP - Peak Pulse Current - % of IPP
120
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPPESD5V0S1UB
www.sot23.com.tw
PU
BL
IC
SOD-523 Package Outline Drawing
TE
CH
Suggested Land Pattern
4
很抱歉,暂时无法提供与“TPPESD5V0S1UB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19513
- 300+0.15979
- 1200+0.14018
- 3000+0.11949
- 15000+0.10930
- 30000+0.10821
- 国内价格
- 20+0.21287
- 200+0.17432
- 600+0.15293
- 3000+0.13036
- 9000+0.11924
- 21000+0.11319
