TPPESD5V0L2BT
2 -L ine Bi -directional TVS Diode
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Operating voltage: 5 V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
Applications
3000
PU
Qty per Reel
Reel Size
7”
TE
CH
TPPESD5V0L2BT
Cellular Handsets and Accessories
Notebooks and Handhelds
Portable Instrumentation
Set Top Box
Industrial Controls
BL
Ordering Information
Part Number
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
IC
250W peak pulse power(8/20µs)
Protects two bi-directional lines
Ultra low leakage:nA level
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
WWW.TECHPUBLIC.COM.TW
TPPESD5V0L2BT
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
250
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±30
Electrical Characteristics (TA=25°C unless otherwise specified)
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
f
VC VBR VRWM
IT
IR
VRWM VBR VC V
IR
IT
Parasitic Capacitance
Reverse Voltage
TE
VR
I
IPP
CH
IT
CESD
BL
Parameter
Symbol
IPP
Small Signal Frequency
Parameter
Breakdown Voltage
Symbol
Bi-Directional TVS
Min
Typ
VRWM
VBR
Max
Unit
5
V
V
6
0.5
µA
Test Condition
IT = 1mA
VRWM = 5V
IR
0.01
Clamping Voltage
VC
7
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
11
V
IPP = 16A (8 x 20µs pulse)
Peak Pulse Current
IPP
16
A
tP=8/20µs
Junction Capacitance
CJ
35
pF
VR=0, f=1MHz, Pin 1 to Pin 3 or
Pin 2 to Pin 3
2
TPPESD5V0L2BT
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPPESD5V0L2BT
WWW.SOT23.COM.TW
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E1
GAUGE
PLANE
SEATING
PLANE
E
C
c
L
L1
1
IC
DETAIL A
2
bxN
A2
A
C A B
3X
aaa C
BL
bbb
e
SIDE VIEW
SEATING PLANE
C
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
SEE DETAIL A
TE
CH
PU
A1
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
C
E
E1
G
X
Y
Z
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
E
E1
4
很抱歉,暂时无法提供与“TPPESD5V0L2BT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29304
- 100+0.23552
- 600+0.20681
- 1200+0.20371
- 3000+0.18523
- 国内价格
- 10+0.31968
- 100+0.25694
- 300+0.22562
- 3000+0.20207
- 6000+0.18328
- 9000+0.17388
