TPPESD24VL1BA
1-Line BI-directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
180W peak pulse power (8/20μs)
Protects one data or power line
Ultra low leakage:nA level
Operating voltage:24V
Ultra low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±15kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
7”
BL
3000
CH
PU
Reel Size
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Peripherals
Pagers Peripherals
TE
TPPESD24VL1BA
Qty per Reel
IC
Applications
Ordering Information
Part Number
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Dimensions and Pin Configuration
1
2
TPPESD24VL1BA
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
ESD per IEC 61000−4−2 (Air)
Value
±20
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
kV
±15
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
Unit
Symbol
Reverse Working Voltage
Breakdown Voltage
Typ
VRWM
VBR
IR
Clamping Voltage
VC
Peak Pulse Current
IPP
Junction Capacitance
CJ
Unit
24
V
IT = 1mA
µA
VRWM = 24V
V
IPP = 1A (8 x 20µs pulse)
60
V
IPP = 3.5A (8 x 20µs pulse)
3.5
A
tp=8/20µs
pF
VR = 0V, f = 1MHz
33
10
Test Condition
V
0.1
VC
TE
Clamping Voltage
Max
26
CH
Reverse Leakage Current
Min
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
WWW.TECHPUBLIC.COM.TW
TPPESD24VL1BA
www.sot23.com.tw
7\SLFDO3HUIRUPDQFH&KDUDFWHULVWLFV7$ &XQOHVVRWKHUZLVH6SHFLILHG
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
110
100
tr = 0.7~1ns
Time (ns)
30ns
60ns
CH
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
IC
80
90%
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
TPPESD24VL1BA
www.sot23.com.tw
Outline Drawing - SOD-323
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
TE
CH
PU
BL
IC
SYM
Land Pattern - SOD-323
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
很抱歉,暂时无法提供与“TPPESD24VL1BA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26374
- 100+0.25978
- 600+0.18058
- 1200+0.17787
- 3000+0.14662
