TPPESD15VL2BT
2 -L ine Bi -directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
250W peak pulse power(8/20 µs)
Protects two bi-directional lines
Ultra low leakage:nA level
Operating voltage:15V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
Applications
Ordering Information
Part Number
TPESD15VL2BT
Qty per Reel
3000
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J STD 020
Reel Size
7”
Cellular Handsets and Accessories
Notebooks and Handhelds
Portable Instrumentation
Set Top Box
Industrial Controls
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
TPPESD15VL2BT
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
250
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
子
Operating Temperature Range
Storage Temperature Range
kV
±30
Tstg
−55 to +125
°C
−55 to +150
°C
Parameter
Symbol
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
舟
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
VR
f
I
IPP
VC VBR VRWM
台
IT
CESD
电
Electrical Characteristics (TA=25°C unless otherwise specified)
IT
IR
IR
IT
VRWM VBR VC V
Parasitic Capacitance
IPP
Reverse Voltage
Small Signal Frequency
Bi-Directional TVS
TPESD15BS3
Parameter
Breakdown Voltage
Symbol
Min
Typ
VRWM
VBR
Max
Unit
15
V
V
16.7
0.5
µA
Test Condition
IT = 1mA
VRWM = 15V
IR
0.01
Clamping Voltage
VC
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
30
V
IPP = 8A (8 x 20µs pulse)
Peak Pulse Current
IPP
8
A
tP=8/20µs
Junction Capacitance
CJ
18
pF
VR=0, f=1MHz, Pin 1 to Pin 3 or
Pin 2 to Pin 3
2
TPPESD15VL2BT
www.sot23.com.tw
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
电
40
td=t IPP/2
10
15
Fig3.
25
30
90
80
70
60
50
40
30
50
75
100
125
10%
tr = 0.7~1ns
30ns
60ns
Power Derating Curve
110
100
% of Rated Power
台
t - Time ( s)
舟
90%
子
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
150
Ambient Temperature –TA (ºC)
3
Time (ns)
TPPESD15VL2BT
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E
C
c
0.25
子
E1
GAUGE
PLANE
SEATING
PLANE
L
L1
DETAIL A
2
bxN
A2
A
C A B
3X
aaa C
SEATING PLANE
C
台
A1
SEE DETAIL A
SIDE VIEW
舟
bbb
e
电
1
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
C
E
E1
G
X
Y
Z
E
E1
4
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.51
0.30
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“TPPESD15VL2BT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39831
- 100+0.32422
- 300+0.28718
- 3000+0.22335
- 6000+0.20110
- 9000+0.18998
- 国内价格
- 10+0.36511
- 100+0.29720
- 600+0.26324
- 1200+0.25929
- 3000+0.20473
