TPPESD12VV1BL
Bi -directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
Low operating voltage: ±12V
Ultra low capacitance: 7pF typical
Ultra low leakage: nA level
Low clamping voltage
2-pin leadless package
Complies with following standards:
Package: DFN1006-2 (1.0×0.6×0.5mm)
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (Lightning) 8A (8/20μs)
RoHS Compliant
Applications
Ordering Information
10000
Reel Size
7”
舟
TPPESD12VV1BL
Qty per Reel
电
Part Number
子
Cellular Handsets & Accessories
Personal Digital Assistants
Display Port
MDDI Ports
Audio Players
PCI Express
Serial ATA
台
Dimensions and Pin Configuration
C
TPPESD12VV1BL
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20μs)
PPK
150
W
Peak Pulse Current (8/20μs)
IPP
8
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Parameter
VRWM
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
电
Symbol
子
Electrical Characteristics (TA=25°C unless otherwise specified)
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
VR
f
Parasitic Capacitance
Reverse Voltage
台
CESD
VC VBR VRWM
Breakdown Voltage
Symbol
Bi-Directional TVS
Min
Typ
VRWM
VBR
VRWM VBR VC V
IPP
Small Signal Frequency
Parameter
IT
IR
IR
IT
舟
IT
I
IPP
Max
12
13.7
Unit
Test Condition
V
V
IT = 1mA
IR
100
nA
VRWM = 12V
Clamping Voltage
VC
V
IPP = 8 A (8 x 20μs pulse)
Junction Capacitance
CJ
10
pF
7
VR = 0V, f = 1MHz
TPPESD12VV1BL
www.sot23.com.tw
Characteristic Curves
Fig1.
8/20μs Pulse Waveform
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
tr
100
Peak Value IPP
80
100%
TEST
WAVEFORM
PARAMETERS
tr=8μs
td=20μs
Percent of Peak Pulse Current %
60
40
td=t IPP/2
90%
10%
10
15
30
t - Time (μs)
Non - Repetitive Peak Pulse Power vs. Pulse Time
电
Fig3.
舟
10
1
0.1
0.01
0.1
台
Peak Pulse Power - PPK (kW)
子
IPP - Peak Pulse Current - % of IPP
120
1
10
100
Pulse Duration - tp (μs)
1000
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPPESD12VV1BL
www.sot23.com.tw
Outline Drawing - DFN1006-2
e
D
h
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
h
b
E
L
c
A
Bottom View
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
电
A1
子
e
台
舟
Land Pattern - DFN1006-2
Y3
Y2
X
SYM
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
Y1
Z
DIMENSIONS
很抱歉,暂时无法提供与“TPPESD12VV1BL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18176
- 1000+0.12068
- 4000+0.10761
- 10000+0.08474
- 国内价格
- 20+0.19829
- 200+0.15542
- 600+0.13166
- 2000+0.11740
- 10000+0.09245
- 20000+0.08576
