TPPESD12VL2BT
2 -L ine Bi -directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
300W peak pulse power(8/20µs)
Protects two bi-directional lines
Ultra low leakage:nA level
Operating voltage:12V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
C
7”
UB
3000
Reel Size
Cellular Handsets and Accessories
Notebooks and Handhelds
Portable Instrumentation
Set Top Box
Industrial Controls
TE
C
HP
TPPESD12VL2BT
Qty per Reel
LI
Applications
Ordering Information
Part Number
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J STD 020
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
TPPESD12VL2BT
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
300
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Electrical Characteristics (TA=25°C unless otherwise specified)
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
f
VC VBR VRWM
IT
IR
IR
IT
VRWM VBR VC V
Parasitic Capacitance
Reverse Voltage
TE
VR
I
IPP
CH
IT
CESD
BL
Parameter
Symbol
IPP
Small Signal Frequency
Parameter
Breakdown Voltage
Symbol
Bi-Directional TVS
Min
Typ
VRWM
VBR
Max
Unit
12
V
V
13.3
0.1
µA
Test Condition
IT = 1mA
VRWM = 12V
IR
0.01
Clamping Voltage
VC
15
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
24
V
IPP = 10A (8 x 20µs pulse)
Peak Pulse Current
IPP
10
A
tP=8/20µs
Junction Capacitance
CJ
24
pF
VR=0, f=1MHz, Pin 1 to Pin 3 or
Pin 2 to Pin 3
2
TPPESD12VL2BT
www.sot23.com.tw
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
3
WWW.TPsemi.COM
TPPESD12VL2BT
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E1
GAUGE
PLANE
SEATING
PLANE
E
C
c
L
L1
1
IC
DETAIL A
2
bxN
A2
A
C A B
3X
aaa C
BL
bbb
e
SIDE VIEW
SEATING PLANE
C
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.18
0.08
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
SEE DETAIL A
TE
CH
PU
A1
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
C
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
C
E
E1
G
X
Y
Z
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
E
E1
4
WWW.TPsemi.COM
很抱歉,暂时无法提供与“TPPESD12VL2BT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.46005
- 100+0.38165
- 600+0.34244
- 1200+0.33730
- 3000+0.31304
- 国内价格
- 10+0.50188
- 100+0.41634
- 300+0.37358
- 3000+0.34150
- 6000+0.31580
- 9000+0.30294
