TPNUP4201MR6T1G
Low Capactiance 4-Line TVS Array
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Ultra low capacitance: 0.3pF typical (I/O to I/O)
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 4 data lines and one power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±15kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
ROHS Compliant
USB 2.0 and USB 3.0 Ports
USB OTG
Digital video interface(DVI)
Monitor and Flat Panel Displays
PCI Express and Serial SATA Ports
Gigabit Ethernet
IEEE 1394 firewire ports
Consumer products (STB, DVD, DSC, DVC…)
BL
3000
Reel Size
7”
CH
PU
TPNUP4201MR6T1G
Qty per Reel
IC
Applications
Ordering Information
Part Number
Package: SOT23-6
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
TE
Dimensions and Pin Configuration
Circuit and Pin Schematic
1
1
TPNUP4201MR6T1G
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
250
W
Peak Pulse Power (8/20μs)
(Vcc-GND)
ESD per IEC61000-4-2 (Air)
±20
VESD
ESD per IEC61000-4-2 (Contact)
kV
±15
TJ
-55 to +125
Storage Temperature Range
Tstg
-55 to +150
IC
Operating Temperature Range
Electrical Characteristics (TA=25°C unless otherwise specified)
Typ
Max
VRWM
Unit
Test Condition
5
V
6
9.5
V
IT=1mA
Breakdown Voltage
VBR
Leakage Current
ILeak
100
nA
VRWM=5V
Clamping Voltage(I/O-GND)
VC
16
V
IPP=4.5A,Tp=8/20μs
CH
Reverse Working Voltage
Min
BL
Symbol
PU
Parameter
17
V
IPP=15A,Tp=8/20μs
0.6
0.7
pF
VR=0V, f=1MHz,
0.3
0.5
pF
VR=0V, f=1MHz,
Clamping Voltage(Vcc-GND)
Junction Capacitance
(I/O to I/O )
CJ
TE
(I/O to GND)
VC
CJ
2
TPNUP4201MR6T1G
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
60
40
td=t IPP/2
10
15
30
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
PU
t - Time ( s)
Fig3.
50
75
100
125
10%
BL
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
150
Ambient Temperature –TA (ºC)
3
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPNUP4201MR6T1G
TE
CH
PU
BL
IC
WWW.SOT23.COM.TW
4
很抱歉,暂时无法提供与“TPNUP4201MR6T1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.28768
- 30+0.27748
- 100+0.25707
- 500+0.23667
- 1000+0.22647
- 国内价格
- 10+0.42570
- 100+0.34284
- 600+0.30136
- 1200+0.29684
- 3000+0.27037
- 国内价格
- 10+0.46440
- 100+0.37401
- 300+0.32876
- 3000+0.29495
- 6000+0.26784
- 9000+0.25424
