TPNUP2301MW 6T1G
Low Capacitance 2-Line ESD Protection
www.sot23.com.tw
Features
Mechanical Characteristics
Working voltage: 70V
Low capacitance:0.5pf
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±20kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
Package: SOT-363 (2.0X2.1X0.35mm)
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
RoHS Compliant
Ordering Information
Qty per Reel
Reel Size
TPNUP2301MW6T1G
3000
7”
Microprocessor Based Equipmenmt
Cell Phone Handsets and Accessories
Personal Digital Assistants (PDAs) and Pagers
CH
PU
Part Number
Portable Instrumentation
BL
IC
Applications
Dimensions and Pin Configuration
TE
VN
1
6
N/C
I/O
2
5
I/O
VP
3
4
N/C
WWW.TECHPUBLIC.COM.TW
TPNUP2301MW 6T1G
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
250
W
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
±25
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±20
Symbol
VRWM
Reverse Leakage Current
IR
Forward Voltage
VF
Clamping Voltage
VC
0.4
TE
Junction Capacitance
Typ
CH
Reverse Working Voltage
Min
CJ
Max
PU
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
0.7
0.5
Unit
Test Condition
70
V
0.5
uA
VRWM = 70V
1.2
V
IF = 1mA
10
V
IPP =20A(8x20us pulse)
1
pF
VR = 0V, f = 1MHz
TPNUP2301MW 6T1G
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
50
75
100
125
150
Ambient Temperature –TA (ºC)
TPNUP2301MW 6T1G
www.sot23.com.tw
Outline Drawing - SOT-363(2.0X2.1)
DIM
D
e1
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
N
01
aaa
bbb
ccc
N
E/2
E1
1
ccc C
2X N/2 TIPS
E
2
e
B
D
A2
A
SEATING
PLANE
bxN
bbb
1.10
0.00
0.10
0.70 0.90 1.00
0.15
0.30
0.08
0.22
1.80 2.00 2.20
1.15 1.25 1.35
2.10 BSC
0.65 BSC
1.30 BSC
0.26 0.36 0.46
(0.42)
6
0°
8°
0.10
0.10
0.30
H
A1
C
.043
.000
.004
.028 .035 .039
.012
.006
.003
.009
.071 .079 .087
.045 .049 .053
.083 BSC
.026 BSC
.051
.010 .014 .018
(.017)
6
8°
0°
.004
.004
.012
BL
aaa C
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
IC
A
C A-B D
GAGE
PLANE
PU
0.15
SEE DETAIL
01
(L1)
DETAIL
A
A
CH
SIDE VIEW
L
c
TE
Land Pattern - SOT-363
X
DIM
C
G
Y
Z
C
G
P
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.073)
.039
.026
.016
.033
.106
(1.85)
1.00
0.65
0.40
0.85
2.70
P
很抱歉,暂时无法提供与“TPNUP2301MW6T1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.89716
- 50+0.71054
- 150+0.61722
- 500+0.54724
- 3000+0.46008
- 6000+0.43211
