TPMMBZ27VALT1G
TPMMBZ27VALT1G
    TECHPUBLIC(台舟)
    SOT-23
    ESD抑制器/TVS二极管 SOT23 62V 3A
TPMMBZ27VALT1G 数据手册
TPMMBZ 27VALT1G 24V TVS Diode Array WWW.SOT23.COM.TW Mechanical Characteristics Features Ordering Information 3000 Reel Size 7” Applications      USB Power & Data Line Protection Monitors and Flat Panel Displays I²C Bus Protection Portable Instrumentation Set Top Box CH TPMMBZ27VALT1G Qty per Reel  Lead Finish: Matte Tin  UL Flammability Classification Rating 94V-0  Pb-Free, Halogen Free, RoHS/WEEE Compliant PU Part Number  Package: SOT23 IC     150 Watts peak pulse power (tp = 8/20μs) Transient protection for high speed data lines to IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC 61000-4-4 (EFT) 40A (5/50ns) Working voltages : 24V Protects one bidirectional line or two unidirectional lines Low operating and clamping voltages Solid-state silicon avalanche technology BL   TE Dimensions and Pin Configuration Circuit and Pin Schematic A WWW.TECHPUBLIC.COM.TW TPMMBZ 27VALT1G 24V TVS Diode Array WWW.SOT23.COM.TW Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 180 W Peak Pulse Current (8/20µs) IPP 3 A ESD per IEC 61000−4−2 (Air) Operating Temperature Range TJ Tstg BL Storage Temperature Range kV ±30 IC ESD per IEC 61000−4−2 (Contact)   ±30 VESD −55 to +125 °C −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Reverse working voltage Reverse breakdown voltage Clamping voltage Junction capacitance   VBR IT=1mA Min Typ 26 Max Unit 24 V 32 V IR VRWM=24V 0.01 1.0 μA VC IPP=3A,t P=8/20μs 45 62 V VRWM=0V, f=1MHz 20 TE Reverse leakage current VRWM Conditions PU Symbol CH Parameter CJ pF WWW.TECHPUBLIC.COM.TW TPMMBZ 27VALT1G 24V TVS Diode Array WWW.SOT23.COM.TW PROTECTION PRODUCTS Typical charateristics Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 60 40 td=t IPP/2 0 0 5 10 15 20 25 30 Time (ns) 30ns 60ns CH Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 TE % of Rated Power tr = 0.7~1ns PU t - Time ( s) Fig3. 10% BL 20 90% IC tr Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) WWW.TECHPUBLIC.COM.TW TPMMBZ 27VALT1G 24V TVS Diode Array WWW.SOT23.COM.TW Outline Drawing - SOT23 D A DIM e1 A A1 A2 b c D E E1 e e1 L L1 N 0 aaa bbb H 3 B C c 0 0.25 IC E1 GAUGE PLANE SEATING PLANE E L L1 DETAIL A 1 2 A2 A C A B 3X aaa C PU bbb BL bxN e SEATING PLANE A1 .035 .000 .035 .012 .003 .110 .082 .047 .015 0° .037 .114 .093 .051 .075 .037 .020 .022 3 .004 .008 .044 .004 .040 .020 .007 .120 .104 .055 .024 8° 0.89 1.12 0.01 0.10 0.88 0.95 1.02 0.51 0.30 0.18 0.08 2.80 2.90 3.04 2.10 2.37 2.64 1.20 1.30 1.40 1.90 BSC 0.95 BSC 0.40 0.50 0.60 (0.55) 3 0° 8° 0.10 0.20 CH SEE DETAIL A TE Land Pattern - SOT23 C SIDE VIEW DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX X Y DIM Z G Y C C E E1 G X Y Z DIMENSIONS INCHES MILLIMETERS (.087) .037 .075 .031 .039 .055 .141 (2.20) 0.95 1.90 0.80 1.00 1.40 3.60 E E1 WWW.TECHPUBLIC.COM.TW
TPMMBZ27VALT1G 价格&库存
很抱歉,暂时无法提供与“TPMMBZ27VALT1G”相匹配的价格&库存,您可以联系我们找货
