TPGBLC18C
1-Line Low Capacitance Bi-directional TVS Diode
WWW.SOT23.COM.TW
Features
Ultra low capacitance: 1.0 pF typical
Ultra low leakage: nA leel
Low clamping voltage
Protects one power line or data line
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
TPGBLC18C
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Peripherals
Pagers Peripherals
Desktop and Servers
BL
IC
Applications
Ordering Information
Part Number
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
PU
Qty per Reel
Reel Size
3000
7”
CH
350W peak pulse power (8/20μs)
TE
Mechanical Characteristics
Dimensions and Pin Configuration
TPGBLC18C
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
ESD per IEC 61000−4−2 (Air)
Value
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
Unit
Symbol
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
VR
f
IT
IR
VRWM VBR VC V
IR
IT
Parasitic Capacitance
TE
CESD
VC VBR VRWM
CH
IT
I
IPP
Reverse Voltage
IPP
Small Signal Frequency
Parameter
Breakdown Voltage
Symbol
Bi-Directional TVS
Test Condition
Min
Typ
VRWM
VBR
Max Unit
18.0
IT = 1mA
V
V
IR
VRWM = 18 V
0.2
µA
Clamping Voltage
VC
IPP = 1A (8 x 20µs pulse)
26
V
Clamping Voltage
VC
IPP = 10A (8 x 20µs pulse)
35
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
1
pF
TPGBLC18C
WWW.SOT23.COM.TW
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
110
100
CH
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
50
75
100
125
Ambient Temperature –TA (ºC)
150
IC
80
90%
tr = 0.7~1ns
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
30ns
60ns
Time (ns)
TPGBLC18C
WWW.SOT23.COM.TW
Outline Drawing - SOD-323
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
1.50
1.80
0.060
0.071
B
1.20
1.40
0.045
0.054
C
2.30
2.70
0.090
0.107
D
1.10
0.043
E
0.30
0.40
0.012
0.016
F
0.10
0.25
0.004
0.010
H
0.10
0.004
TE
CH
PU
BL
IC
SYM
Land Pattern - SOD-323
SYM
DIMENSIONS
MILLIMETERS
INCHES
A
3.15
0.120
B
0.80
0.031
C
0.80
0.031
很抱歉,暂时无法提供与“TPGBLC18C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.62426
- 50+0.50666
- 600+0.40376
- 1200+0.39770
- 3000+0.33624
- 国内价格
- 10+0.54238
- 100+0.42958
- 600+0.33088
- 1200+0.32592
- 3000+0.26611
- 国内价格
- 5+0.68796
- 50+0.55836
- 150+0.49356
- 500+0.44496
- 3000+0.37055
- 6000+0.35100
