TPESD9B3.3ST5G
1-Line Bi-directional Diode
www.sot23.com.tw
Features
Mechanical Characteristics
80W peak pulse power (8/20 μs)
Protects one data or power line
Operating voltage: ±3.3V
Ultra low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (SURGE) 8A (8/20us)
Ultra low leakage: nA level
UL Flammability Classification Rating 94V-0
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
Mobile Phones and Accessories
Battery Protection
USB VBus
Power Line Protection
LI
7”
Hand Held Portable Applications
CH
PU
B
8000
Reel Size
Dimensions and Pin Configuration
TE
TPESD9B3.3ST5G
Qty per Reel
Package:SOD-923(0402)
Applications
Ordering Information
Part Number
C
1
TPESD9B3.3ST5G
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
80
W
Peak Pulse Current (8/20µs)
IPP
8
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Reverse Working Voltage
Breakdown Voltage
VRWM
VBR
IR
Clamping Voltage
VC
Clamping Voltage
VC
IT = 1mA(Pin1-Pin2)
IPP = 1A (8 x 20us pulse)
(Pin1-Pin2)
IPP = 8A (8 x 20us pulse)
(Pin1-Pin2)
VR = 0V, f = 1MHz
(Pin1-Pin2)
TE
CJ
Min
3.6
Typ
4
VRWM = 3.3
. V(Pin2 -Pin1)
CH
Reverse Leakage Current
Junction Capacitance
Test Condition
LI
Symbol
PU
B
Parameter
C
Electrical Characteristics (TA=25°C unless otherwise specified)
2
15
Max Unit
3.3
V
5.6
V
0.08
µA
7
V
10
V
pF
TPESD9B3.3ST5G
www.sot23.com.tw
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
80
BL
60
40
10
15
Fig3.
Power Derating Curve
30
TE
% of Rated Power
110
100
25
CH
t - Time ( s)
PU
td=t IPP/2
80
70
60
50
40
30
50
75
90%
IC
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
100
125
150
Ambient Temperature –TA (ºC)
3
10%
tr = 0.7~1ns
30ns
60ns
Time (ns)
TPESD9B3.3ST5G
www.sot23.com.tw
Outline Drawing - SOD-9 23(0402)
A
B
C
A
B
C
D
E
F
BL
E
PU
D
TE
CH
F
DIMENSIONS
INCHES
MM
MAX
MIN
MAX
MIN
.037
.041
0.95
1.05
.030
.033
0.75
0.85
.022
.026
0.55
0.65
.014
.017
0.36
0.43
.006
.010
0.15
0.25
.003
.007
0.07
0.17
IC
DIM
Land Pattern - SOD-9 23(0402)
0.90 mm
0.40mm
0.30mm
4
NOTE
很抱歉,暂时无法提供与“TPESD9B3.3ST5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.24473
- 100+0.19612
- 1600+0.15355
- 3200+0.13900
- 8000+0.13167
