TPESD5B5VL-2/ TR
Bi -directional TVS Diode
www.sot23.com.tw
Mechanical Characteristics
Features
Protects one data or power line
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Complies with following standards:
– IEC 61000-4Air discharge: ±15kV
Contact discharge: ±8kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
Package: SOD-523
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Applications
Ordering Information
7”
Portable Instrumentation
Digital Cameras
Peripherals
Audio Players
Keypads, Side Keys, LCD Displays,USB2.0
PU
3000
Reel Size
Notebooks and Handhelds
CH
TPESD5B5VL-2/TR
Qty per Reel
Personal Digital Assistants
TE
Part Number
Cellular Handsets and Accessories
BL
IC
Dimensions and Pin Configuration
1
TPESD5B5VL-2/ TR
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
ESD per IEC 61000−4−2 (Air)
Value
±15
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
Unit
kV
±8
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VBR
Maximum Reverse Leakage Current @ VRWM
Test Current
Forward Current
Forward Voltage @ IF
Ppk
Peak Power Dissipation
CH
IF
VF
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol
Min
V
Uni−Directional TVS
Typ
VRWM
VBR
IR VF
IT
IPP
Capacitance @ VR = 0 and f = 1.0 MHz
TE
C
VC VBR VRWM
Breakdown Voltage @ IT
IT
IF
BL
IR
Working Peak Reverse Voltage
I
PU
VRWM
IC
Symbol
Max
Unit
5
V
6
Test Condition
V
IT = 1mA
IR
200
nA
VRWM = 5V
Clamping Voltage
VC
10
V
IPP = 1A (8 x 20µs pulse)
Junction Capacitance
CJ
3
pF
VR = 0V, f = 1MHz
2.5
2
WWW.TECHPUBLIC.COM.TW
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
10
4
Peak Power_Ppp(kW)
Junction CapacitanceCj(pF)
5
3
2
1
1
0.1
0.01
2
3
4
Reverse Voltage_VR(V)
0.1
5
Junction Capacitance vs. Reverse Voltage
10
Pulse Duration_tp(uS)
100
Peak Pulse Power vs. Pulse Time
120
100
BL
Peak Pulse Current (Ipp)
90
70
60
PU
Ipp/2
50
40
CH
30
% of Rated Power
100
80
TE
% of Peak Pulse Current
1
IC
Time_t(uS)
60
80
60
40
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
8 X 20uS Pulse Waveform
ESD Clamping Voltage
+8 kV Contact per IEC61000−4−2
-8 kV Contact per IEC61000−4−2
3
TPESD5B5VL-2/ TR
www.sot23.com.tw
BL
IC
SOD-523 Package Outline Drawing
TE
CH
PU
Suggested Land Pattern
4
很抱歉,暂时无法提供与“TPESD5B5VL-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09428
- 10+0.08652
- 30+0.08497
- 国内价格
- 20+0.24290
- 200+0.19473
- 600+0.16805
- 3000+0.13727
- 9000+0.12334
- 21000+0.11589
- 国内价格
- 20+0.22265
- 300+0.17850
- 1200+0.15404
- 3000+0.12583
