TPESD5B5.0ST1G
Bi -directional TVS Diode
WWW.SOT23.COM.TW
Features
Mechanical Characteristics
Protects one data or power line
Package: SOD-523
Ultra low leakage: nA level
Lead Finish: Matte Tin
Low operating voltage: 5V
Case Material: “Green” Molding Compound.
Low clamping voltage
UL Flammability Classification Rating 94V-0
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
RoHS Compliant
Ordering Information
Qty per Reel
IC
7”
3000
CH
TPESD5B5.0ST1G
Reel Size
PU
Part Number
Cellular Handsets & Accessories
Digital Visual Interface (DVI)
Display Port
MDDI Ports
USB Ports
PCI Express
Serial ATA
BL
TE
Applications
Dimensions and Pin Configuration
TPESD5B5.0ST1G
WWW.SOT23.COM.TW
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
IPP
7
A
Peak Pulse Current (8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±30
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Nominal Reverse Working Voltage
IR
Reverse Leakage Current @ VRWM
VBR
Reverse Breakdown Voltage @ IT
PU
VRWM
Test Current for Reverse Breakdown
VC
Clamping Voltage @ IPP
IPP
Maximum Peak Pulse Current
f
VC VBR VRWM
IT
IR
IR
IT
VRWM VBR VC V
Parasitic Capacitance
Reverse Voltage
TE
VR
I
IPP
CH
IT
CESD
BL
Symbol
IPP
Small Signal Frequency
Parameter
Breakdown Voltage
Symbol
Bi-Directional TVS
Min
Typ
VRWM
VBR
6
7
Max
Unit
Test Condition
5
V
9
V
IT = 1mA
IR
0.2
uA
VRWM = 5V
Clamping Voltage
VC
7
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
9
V
IPP = 7A (8 x 20 s pulse)
Junction Capacitance
CJ
15
pF
VR = 0V, f = 1MHz
TPESD5B5.0ST1G
WWW.SOT23.COM.TW
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
t - Time ( s)
Power Derating Curve
tr = 0.7~1ns
Time (ns)
30ns
60ns
CH
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
10%
PU
Fig3.
IC
80
90%
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
50
75
100
125
150
Ambient Temperature –TA (ºC)
WWW.TECHPUBLIC.COM.TW
TPESD5B5.0ST1G
WWW.SOT23.COM.TW
Outline Drawing - SOD-523
SOD-523
A
Millimeters
1
2
C
K
Max
Min
Max
A
1.10
1.30
0.043
0.051
B
0.70
0.90
0.028
0.035
C
0.50
0.70
0.020
0.028
D
0.25
0.35
0.010
0.014
J
0.07
0.20
K
0.15
0.25
0.006
0.010
S
1.50
1.70
0.059
S
0.067
0.0028 0.0079
PU
J
Min
BL
D
DIM
IC
B
Inches
CH
Land Pattern - SOD-523
TE
Recommended Mounting Pad Layout
1.40
0.0547
0.40
0.0157
0.40
0.0157
Dimensions in ( millimeters )
inches
很抱歉,暂时无法提供与“TPESD5B5.0ST1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16222
- 200+0.12852
- 600+0.10984
- 3000+0.09483
- 9000+0.08511
- 21000+0.07992
- 国内价格
- 1+0.11310
- 3000+0.09150
- 国内价格
- 20+0.14870
- 300+0.11781
- 1200+0.10068
- 3000+0.08692
