TPESD5431N
1-Line Bi-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
⚫ Package: DFN1006-2 (0402)
⚫ Lead Finish: Matte Tin
⚫ Ultra small package: 1.0x0.6x0.5mm
⚫ Ultra low capacitance: 15pF typical
⚫ Case Material: “Green” Molding Compound.
⚫ Moisture Sensitivity: Level 3 per J-STD-020
⚫ Ultra low leakage: nA level
⚫ Low operating voltage: ±3.3V
⚫ Terminal Connections: See Diagram Below
⚫ Low clamping voltage
⚫ 2-pin leadless package
Applications
IC
⚫ Complies with following standards:
⚫ – IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
- - (Lightning) 9A (8/20μs)
μs)
⚫ – IEC61000-4-5
⚫ RoHS Compliant
BL
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Digital Cameras
Peripherals
PU
⚫ Lead Finish: NiPdAu
Ordering Information
Qty per Reel
Reel Size
TPESD5431N
3000
10000
7”
TE
CH
Part Number
Dimensions and Pin Configuration
WWW.TECHPUBLIC.COM.TW
TPESD5431N
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
100
W
Peak Pulse Current (8/20µs)
Ipp
9
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Operating Temperature Range
kV
±30
BL
Storage Temperature Range
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
VBR
Reverse Leakage Current
Clamping Voltage
Junction Capacitance
3.7
4.8
IR
VC
TE
Clamping Voltage
VRWM
Typ
CH
Breakdown Voltage
Min
VC
CJ
Max
PU
Parameter
15
2
Unit
3.3
V
6
V
0.05
uA
Test Condition
IT = 1mA
VRWM = 3.3V
6
V
Ipp=1A(8x 20us pulse)
11.5
V
Ipp=9A(8x 20us pulse)
pF
VR = 0V, f = 1MHz
TPESD5431N
www.sot23.com.tw
TE
CH
UB
LI
C
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
3
TPESD5431N
www.sot23.com.tw
DFN1006-2 Package Outline Drawing (0402)
h
h
A
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
b
E
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
L
A1
c
A
Bottom View
0.65 BSC
BL
e
IC
e
D
0.026 BSC
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Y3
Y2
TE
Suggested Land Pattern
CH
PU
E
Y1
SYM
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
4
很抱歉,暂时无法提供与“TPESD5431N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14870
- 1000+0.10296
- 4000+0.09316
- 10000+0.07158
