TPESD5341N
1-Line Uni-directional TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
⚫ Package: DFN1006-2 (0402)
⚫ Lead Finish: Matte Tin
⚫ Ultra low capacitance: 0.35pF typical
⚫ Ultra low leakage: nA level
⚫ Case Material: “Green” Molding Compound.
⚫ Moisture Sensitivity: Level 3 per J-STD-020
⚫ Low operating voltage: ±5V
⚫ Low clamping voltage
⚫ Terminal Connections: See Diagram Below
⚫ Shipping Qty : 10000pcs/7Inch Tape & Reel
⚫ 2-pin leadless package
⚫ Complies with following standards:
⚫ – IEC 61000-4-2 (ESD) immunity test
Applications
Air discharge: ±15kV
Contact discharge: ±8kV
- - (Lightning)3.3A (8/20μs)
⚫ – IEC61000-4-5
⚫ RoHS Compliant
⚫ Cellular Handsets and Accessories
⚫ Personal Digital Assistants
⚫ Notebooks and Handhelds
⚫ Portable Instrumentation
⚫ Digital Cameras
⚫ Lead Finish: NiPdAu
子
⚫ Peripherals
⚫ Audio Players
电
⚫ Keypads, Side Keys, LCD Displays
台
舟
Dimensions and Pin Configuration
I/O
PIN1
Pin1
Pin2
PIN2
GND
WWW.TECHPUBLIC.COM.TW
TPESD5341N
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
70
W
Peak Pulse Current (8/20µs)
Ipp
3.3
A
ESD per IEC 61000−4−2 (Air)
±15
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
子
Storage Temperature Range
kV
±8
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
VBR
Reverse Leakage Current
Clamping Voltage
Junction Capacitance
Max
Unit
5
V
V
6
Test Condition
IT = 1mA
IR
0.08
uA
VC
15
V
Ipp=1A(8x 20us pulse)
V
Ipp=3.3A(8x 20us pulse)
pF
VR = 0V, f = 1MHz, Pin 1 to Pin 2
台
Clamping Voltage
Typ
舟
Breakdown Voltage
VRWM
Min
电
Parameter
VC
CJ
0.35
2
VRWM = 5V
TPESD5341N
www.sot23.com.tw
舟
电
子
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
台
% Of Rated Power
FIGURE 3
TPESD5341N
www.sot23.com.tw
DFN1006-2 Package Outline Drawing (0402)
e
D
h
h
A
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
b
E
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
L
A1
c
A
Bottom View
0.65 BSC
子
e
0.026 BSC
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
舟
电
E
台
Suggested Land Pattern
Y3
Y2
SYM
Y1
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
4
很抱歉,暂时无法提供与“TPESD5341N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11830
- 100+0.10855
- 500+0.10205
- 1000+0.09555
- 5000+0.08775
- 10000+0.08450
- 国内价格
- 20+0.20790
- 200+0.16427
- 600+0.14008
- 2000+0.12550
- 10000+0.10617
- 20000+0.09947
- 国内价格
- 20+0.19058
- 1000+0.12840
- 4000+0.11504
- 10000+0.09732
